If you haven't already, you should go to Range Rovers as it has all sorts of info on these cars.
In answer to your question, yes it is possible but it involves buying a whole new car and changing nearly every piece of electronics on the car and possibly even the engine. So know you would probably not want to do it. Check on the other forum, but I don't believe anybody has been successful. I think the modulators were similar, they had a stainless steel washer instead of the plastic on ours that breaks and causes complete brake failure.
I wouldn't be doing it unless you had a complete donor car.
Stu
