Thread: IPhone wireless OBD2 scanner/ app
    Oct 2008
    Heart in the Deep Nth of FNQ,Body in the Deep Nth of Brisneyland
    Nov 2005
    Maudsland, QLD
    Looks cool...has any tested it with a landy...be a great tool to reset fault codes on my p38
    2023 Defender 130 D300
    SOLD - 2010 Discovery 4 V8
    SOLD - 2008 Range Rover Vogue L322 TDV8
    SOLD - 2006 Range Rover Sport L320 TDV6
    SOLD - 2002 Range Rover L322 TD6
    SOLD - 2002 Discovery 2 TD5
    SOLD - 1997 Range Rover 4.6 HSE
    SOLD - 1999 Range Rover 4.0 SE
    I reckon it will only work to a degree..
    being as though I have had an OBD11 scanner on the puma it will only pick up generic codes not ones that are Land Rover specific.
    Had a look at this and a few things stand out.
    No mention of CANbus, so not sure about working on newer vehicles
    I doubt it will work on anything other than the ECM and may not work on diesels
    If it does work I suspect it will be about the equivalent of a ScanGaugeII but with a more user friendly interface.
    As the wireless set up runs of the OBDII port it will draw power from there and there is no mention of what it does whilst the ignition is OFF. This may therefore drain the battery.
    Would be nice if the site listed compatible vehicles.
    Jul 2010
    PERTH
    Hi just got an i-phone4 and there is two apps from go-link to use this phone as a code reader and display realtime info but it depends on what the car maker make available. the lead to connect the phone to the obd plug was $99 (u.s) and also charges the phone.
