Mike,
Definately a reg problem, I just had the same with a 1995 110 last week. Complained about having to add water to the battery continually, Boiled his battery almost dry within a month apparently
I replaced the whole unit with a Disco 100 amp one, killed 2 birds as the standard unit on Defender Tdi is only 65A.
If you DO go this way, you will have to fit another length serpentine belt if your Defender is prior to 1996, as the pulley diameter is smaller on the new ones I have been buying lately. You can change the pulleys over, but on some replacement alts the shaft size varies aswell. The belts are 1595mm long (early), and 1580mm long (later, 1996 on).
JC
Reason: Add more info
