Thread: Conquering Mt Range Rover
    May 2010
    When last we left Goldiloxgirl, she was busy fending off an onslaught of hard springers. Meanwhile, having obtained temporary relief from Bump Stop Central- that dreaded beep beep beep that P38a owners know may strike at any time and transform their precious chariots into highly refined Go-Karts- our fearless female metallic warrior pressed on with other important repairs- repairs designed to make her Go-Kart stop.
    Her introduction to replacing the front rotor and brake pads may have taken 36 hours- for one wheel- but the next hapless spinning disc was whisked off and replaced along with the pads in less than 40 minutes. With confidence rising, she quickly jacked up the rear of the car and replaced the pads on the left in under 15 minutes. This woman was cooking with gas and there was no stopping her. Finally she came to the right hand rear pads.
    With the pads removed and the piston compressor in place ready to push the piston into to caliper, she paused. Deciding first to circumvent the reservoir overflowing, she unscrewed the bleed nut and set about pumping out excess fluid. It was only after she heard the clang of metal and observed the river of fluid gushing from the caliper that she realised one ought to perform this function whilst the caliper sits on the disc and not after the piston compressor has been installed. Needless to say, the braking force of the piston overwhelmed the tinny tool and the tiny piston soon found itself basking in the light of day.
    With her female enthusiasm for conquering paths guarded by mortal men now dampened with brake fluid and with the assistance of a new brake piston compressor, she finally restored order to the chaotic state of braking affairs. That feeling of achievement, the sense of power one gains after having climbed Mt Range Rover, was once again hers. Sitting in the leather saddle, she held the wooden reins of her stead as it purred off into the night, knowing with certainty that mighty beast would come to a sure stop when she utters the command ‘Whoa’.
    Kindest Regards,
    Lani
    Disclaimer: Goldiloxgirl is not qualified to give mechanical advice. If pain persists, seek independent technical support.
    d@rk51d3 Guest
    Well done.
    May 2008
    Good on you Lani, glad you got it sorted. This is just the sort of project that is great to see documented with a few photos so the rest of us can tackle it with some confidence.
    Cheers, Paul.
    Well done, sounds like an interesting exercise, one which I am contemplating embarking upon in the near future.
    I always said I wouldn't touch brakes as they are too important, but last year I found myself needing to bleed the brakes several times after the modulator rebuild.
    I have become quite proficient at a full brake bleed on my P38, and since purchasing a simple pressure bleed kit from the UK, I can even do it by myself in just over an hour. Takes about 2 - 3 litres of brake fluid.
    I shall try doing the disc and pad renewal in the next few months. If I need help I will give you a hoy !
    Dave.
    2011 Range Rover Sport SDV6 Autobiography
    2004 Freelander TD4 SE
    1997 Range Rover 4.6 HSE
    1994 Range Rover Vogue
    WasabiPimpNinja Guest
    Nicely done. I used to be worried abut doing my brakes, but I've done that many sets over the years now it's like second nature. Sounds like you had "fun" (I use that term loosely) and learnt a fair bit along the way.
    And it's good to see a write up with a bit of artistic flair and humour
    Keels.
    Avoca Beach
    Go girl!!
    Just in future , a syringe from a chemist is a good way to suck out the master cylinder.It also helps save new fluid if you empty out the old from the master cylinder before flushing, a memory that came to me just after I had topped up the Master cylinder of my Honda Jazz with new fluid when flushing last week.
    The procedure with the caliper piston is to undo the bleeder into a bit of hose into a bottle with some fluid in the bottom, then push in the caliper tool, in my case a large screwdriver. This prevents yucky old fluid going back into the master cylinder, and makes it a lot easier to push the piston back. Immediately nip up the bleeder. Then put the new pads in and then flush/bleed . It is a lot easier with a Mityvac , not to be confused with most on the internet or a pressure bleeder.
    Regards Philip A
    May 2010
    No probs Triple 3
    I would be glad to help in any way Dave (subject to my usual disclaimer of course). It really is not that hard once one gets a grip of what actually needs to be done.
    Paul; shortly I will be putting up an account of my recent vanquishing of the Demons of EAS (complete with pictures if I can upload them). I noticed my first post on the brake repair was shifted to the General Chat Forum so I may post over there.
    Quote Originally Posted by adm333 View Post
    Dave.
    Go girl!!
    Regards Philip A
    I second that, a syringe is a good idea. Do not ever try to syphon it out of the master cylinder like a friend of mine. He grabbed the Shell Helix Ultra instead of the brake oil to top up the master cylinder. Then in another moment of pure genius decided to try and syphon it out with a small hose.
    Apparently brake fluid tastes exactly like it smells.
    Keels.
    May 2010
    Wink Don't share a needle with Master Cylinders
    I guess its not a good idea to use the syringe for cake decorations afterward either, hey?
    Regards,
    Lani
    Disclaimer: Goldiloxgirl is not qualified to give medical advice and she does not recommend using the brake fluid contaminated syringe for insulin injections
    Quote Originally Posted by WasabiPimpNinja View Post
    Keels.
    Wollongong
    Thumbs up
    What a great story, looking forward to your next adventure goldiloxgirl. It's a shame more people can't tell a story like you.
