Results 1 to 1 of 1
Thread: Series 1 parts information
    East-South-East Girt-By-Sea
    1.20 MB
    This thread is to list Land Rover series 1 parts from regular manufacturer catalogues (i.e. not Rover part numbers).
    Also check main list ( http://www.aulro.com/afvb/series-lan...formation.html )
    The thread is locked to avoid filling it up with chat. If you have an item PM me and I'll list it in the thread.
    ___________________________________________
    Engine
    Accelerator spring 80"
    Redline 3" throttle spring - close copy of the real thing - (available from Autobarn,)
    early 80" Distributor cap and fan belt and amp-meter from a TEA20 Ferguson tractor. - (available from Bare-co agricultural parts)
    Contact set:
    Lucas LU 407050 contact set and the
    condenser:
    Lucas LU 407044.
    Fan Belts:
    BOSCH fan belts 15A0980 fits the series 1 motor
    Universal Joints
    Series 1 & Series II Front and Rear prop shafts = Hardy Spicer* K5-L4R
    *Hardy Spicer number also used by Toyo bearing Co.
    Suspension:
    Shock Absorbers 80":
    Rear - Monroe 15-0060+
    Rear - Gabriel 81147 (available Super Cheap Auto)
    Axle Assemblies:
    Rear wheel bearing semi floating: SKF No 88128
    Swivel Joints - Universal joints Series 1 Hardy Spicer K5-GB35
    Front halfshaft bearing 80": KSM (Japan) Part No. RLS11 (OEM prob "FBC" Part No. LS12 1/2)
    Lighting
    Side lamps 1952 through 1957 models: Lucas L489
