Results 1 to 10 of 11
Thread: Nuts!
    May 2003
    On The Road
    Nuts!
    What is the technical reason to use a cone nut rather than a nylok?
    Australia
    Assuming you mean the locking properties of the nut are caused by the nut being formed into a conical shape rather than a wheel nut conical style.
    These are for high heat applications where a nyloc type nut will melt or be too soft to adequately retain the nut.
    These nuts are not always found in high heat applications, as they can (not always) also be cheaper than nylocs depending on the manufacturers stock requirements and order run.
    May 2003
    On The Road
    no, not wheel nuts
    ok,,
    if bolt is 10.9 hardness, (think truck suspension) is a nylock suitable? The nuts are rattled up to squeeze pivot bushes into place.
    its got nothing to do with the hardness of the bolt/nut your fitting, the cone/wedge/deformed thread (all the same class of lock nut) are used where you would normally use a nyloc but cant because of exposure to heat, oil or other substance that will deteriorate the nylon in the nyloc nut.
    it will also be used in place of a nyloc in a minimum thread length environment where you cant get enough protruding thread through the nut to ensure the nyloc will work correctly.
    Nyloc nuts are available in higher tensile strengths if you need them but in your application I would suggest not rattling the fixture up with the nyloc. Use a surrogate nut to seat everthing then remove that nut and wind the nyloc on in place remembering that once a nyloc has had more than 5 or 6 turns of thread through the nylon it begins to loose its "hold" and may not be completely effective. The same goes for cone/wedge/deformed thread type nuts. if you have a lot of thread left over you might consider cutting the extra thread off with a hacksaw and cleaning up the leading turn prior to putting on a nyloc, double nutting or converting over to a castellated nut and split pin configuration.
    Bacchus Marsh Vic.
    no, not wheel nuts
    ok,,
    Nylock's are used on the draw bar bush pins on dog trailers and some suspension points .
    I say not a problem
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    sorry to be dumb,
    but what do you lot call a cone nut?
    Safe Travels
    harry
    May 2003
    On The Road
    Hi Harry
    just an over-tall nut that rounds off/up towards the centre, from what I can figure the top cone portion of the threads are distorted(?) to provide a locking meckanism(RON!!!)
    maybe only 2 or 3 threads more than normal,
    Adelaide - Torrens Park
    meckanism(RON!!!)
    mechanism
    May 2003
    On The Road
    Goodaye Ron!
    ok pedro,
    from that description it sounds like what we call a 'metal locknut' where the threads in the locking section are either 'out of round' or distorted
    or a cut or several is put into the locking part and the that part of the nut is closed a bit so the threaded bit bites.
    metal locknuts are primarily used in high temp applications
    if you can screw the nut on past the locking part, unscrew it and chuck it. [away]
    Safe Travels
    harry
