Results 1 to 10 of 13
Thread: Aircon in Tdi Defender not working
    dmdigital's Avatar
    ... well not working at all I mean it doesn't really do much so I never really use it but I have a friend from down south visiting and so went to put it on today. Nothing happened Found one of the two 15A fuses (2nd from left) had blown. Replaced this and it blew as well, stuck a larger 25A fuse in and it was OK but the wire from the relay to the fuse got hot. It's a WA (98MY) VIN 300Tdi.
    Does anyone have any wiring diagrams for these A/C units or more information on them?
    Jul 2008
    Queensland
    Don't do what I did and put a larger fuze in and then the loom got hot and caused an electrical fire.
    have you got the Rave CD for the Defender as this contains the electrical wiring manual for the 300Tdi.
    good luck cheers Mark
    Land Rover 200 Tdi Defender owner
    NSW far north coast
    Quote Originally Posted by 2234jones View Post
    Except that the air conditioner is an Oz made/fitted system.
    I should have an Aussie A/C wiring diagram somewhere in the computer, I hope.
    {edit} Sorry, looks like it's in the lap top, and I can't get the file out of that one......
    Jan 2009
    On the road around Australia
    Quote Originally Posted by rick130 View Post
    Indeed - the RAVE CD doens;t contain the wiring diagram for it. But it's a pretty straightforward setup - two relays under the passenger seat control the blower in the cab, and the fan in front of the radiator. I'd be swapping these out first before following the cables for a potential short. You will find that most of the cables in the A/C wiring loom seem to be unused for some reason...
    deezilfither Guest
    Aircon in Tdi not working
    Had no clutch engagement on A/C compressor . Have a look on this channel go to page 21 and dated 4th April 2010. reads90.
    This bit of info saved me hours, found the wiring harness connector loose on temp control unit.Cleaned with electro clean and refitted plug securely,all works fine. What I did note the blower fan for A/c worked and the Condensor fan[in front of radiator]worked, but no clutch engagement regardless where I placded the temp control switch.Hope this may help.
    Regards Rusty.
    The wiring diagram should be in a post somewhere on this forum.
    I posted it in reply to someone else.
    I can't log on to my website at the moment to check the file name/location as I've forgotten my password.
    May 2006
    Quote Originally Posted by mike_ie View Post
    Re location of these two relays under the passenger seat: The problem may be due to non conducting rusty terminals on them caused by the corrosive atmosphere in this compartment with the battery. Have moved mine out of there.
    Sandstone Point Qld
    I think this is it Ron, got me out of trouble a few months ago 4th post down
    Fuse box under passengers seat on Defender 300TDi
    Aaron & Jacinta
    1994 300Tdi Defender
    Quote Originally Posted by MacFamily View Post
    By gum, that's it. Thanks for that.
    I've now uploaded it to the files area.
    NSW far north coast
    Ron, that's twice now you've provided me with that diagram, once by email years ago (and lost on my old HD when it crashed) and now here again.
