G'day, They are larger on the front in S2/S2A 88", so I guess you would assume that it would be that way for the S1, hope that helps cheers dennis
Hello Folks,
The drum brakes on Matilda are the 10 inch version all around. Are the correct wheel cylinders, for the 2 front brakes, larger than those fitted to the rear?
Dan.
2007 Defender 110
1993 BMW R100LT
The 86" and 88" S1 use exactly the same wheel cylinders as the SII and SIIa 88"
Yes they are larger at the front.
