Motor vehicle recovery straps
Printable view
Recovery straps, or 'snatch straps', are used to free bogged or immobilised vehicles. They are usually made from heavy-duty nylon or polyester.
These do not include vehicle lifting slings or tie-down straps, wire cable, chain, rope or straps for conventional towing situations.
Snatch straps connect two vehicles, so one vehicles can free another from being immobilised or bogged.
The straps apply a stored elastic force that enables a vehicle to be ‘sprung’ from its bogged position.
Danger risk
When the straps stretch and release energy under tension, it exerts tremendous forces.
People have been injured or killed after being struck when strap dislodge or vehicle components break off during the recovery process.
What can you do?
Always take care to choose the correct snatch strap for your needs.
Some straps have a ‘breaking strength’ that is three times the vehicle’s gross vehicle mass (GVM). This may be too strong to stretch properly and will rip vehicle components off during the recovery.
Always follow the product’s instructions carefully, and heed all safety warnings and recommendations.
Safe use
When you use the straps:
from: Buying motor vehicle recovery straps : Department of Employment, Economic Development and Innovation
- ensure the strap’s stated breaking strength is appropriate for the gross vehicle mass (GVM), including load weight, of the individual vehicle being recovered
- ensure the strap is suited to the GVM rating of the lighter vehicles in the recovery
- never attach the strap to a standard tow ball or standard vehicle tie-down point
- only attach a strap to a suitable rated vehicle recovery point or device
- do not use the strap for lifting or conventional towing
- ensure the strap is undamaged and in a usable condition
- ensure that the strap’s strength and stretch is reduced when it is saturated (water logged).
- use a damper device, such as a recovery damper, heavy bag or blanket draped over the strap, to limit any unintentional rebound
- ensure that any people outside the vehicles stand far enough from the vehicles - at least 1.5 times the non-stretched length of the strap. They must never stand in the line of recovery.
