Results 1 to 8 of 8
Thread: Defender Stud Pattern
    VladTepes's Avatar
    Bracken Ridge, Qld
    I've got some standard tubed rims from my 1995 130 Defender twin cab and the question has arisen.. will these fiot ANY model Defender (eg all models).
    What about a 2000 model specifically ?
    I'm pretty sure I know the answer but I want someone who ACTUALLY knows to say so.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Vlad, Vlad, Vlad!
    The Good Oil is your friend.
    Defenders still use the tried and true 5 studs on a 6.5 inch PCD.
    Nov 2007
    Gold coast
    Further info for you...
    All 90/110 wheels are 33mm, only the latest XD/Wolf type are 20.6mm
    ANR4636PM are Standard 5.5F x16 wheels for 90/110 are welded construction in primer finish, the earlier NRC7578 were rivetted construction.
    ANR1543PM are 6.5L x 16 heavy duty rivtted construction
    ANR5593PM are 6.5J x 16 x 20.6mm XD/Wolf are welded construction, or ANR4583PM rivetted construction
    ANR5593PM is the tubed version of the Wolf rim.
    ANR1534PM (20.6 Offset) is listed as One Ton rim .They are only suitable for tubed tyre usage.They are an inch wider with that extra inch going on the outside (ie it looks like a wider standard 110 steel wheel) with slightly less offset than the 5.5 inch wheels
    272309 is an old 109 wheel. They are 5.5″ wide with a different offset than the anr4636.
    (5.5 inch rims have 33mm of offset, the 6.5 inch rims have 20.6mm of offset).
    Tubeless.
    ANR4583PM 6.5J x 16 130 and Wolf XD
    NTC5193PM 7.0 x 16 Discovery
    Tubed.
    NRC7578PM 5.5F x 16 (riveted centre) 90 and 110
    ANR4636PM 5.5F x 16 (welded centre) 90 and 110
    NTC4135PM 6.0J x 16 (riveted centre) 90 only
    ANR4635PM 6.0J x 16 (welded centre) 90 only
    ANR1534PM 6.5L x 16 HD 110 and 130
    ANR5593PM 6.5J x 16 130 and Wolf XD
    Land Rover Wheel Sizes
    Model Rim Dia Width Offset Part#
    88 ‘59 thru ‘67 16″ 5″ 1″ 231601PM
    88 ‘67 thru ‘74 15″ 6″ 1″ NLA
    109 ‘59 thru ‘71 16″ 5.5″ 1.75″ 272309
    109, 90, 110, 88 16″ 5.5″ 2″ NRC7578PM
    130, 110 USA 16″ 6.5″ 2.25″ ANR1534PM
    272309 109, offset from rim centre line 1 13/16″ (1.8125″) Road wheel, well base rim type, 5.5″ x 16″
    568966 109, offset from rim centre line 1 5/16″ (1.3125″) Road wheel, well base rim type, 5.5″ x 16″
    VladTepes's Avatar
    Bracken Ridge, Qld
    What abloody champion !
    gone
    1996 Discovery 1
    current
    NSW far north coast
    Quote Originally Posted by juddy View Post
    [snip]
    FWIW my ANR4583 rim is welded
    Looks identical to the ANR5593 except it has a safety bead for tubeless use.
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    I don't think the above list is strictly accurate in some respects. The distinction for example, as ric130 points out, between rivetted and welded construction is probably not a valid distinction between the part numbers.
    Other points I note are that it specifies 88 Landrovers 1959 -67 when 1959 is not a production change year. In fact, the same wheels were fitted to 88 from 1956. And they did not change to 15" wheels in 1967 - the only 88s sold here with 15" wheels were the Game, and they did not use Landrover wheels.
    I suspect the list applies only to a particular market, and that market is not Australia.
    Nov 2007
    Gold coast
    I think you could be right..
    I had a rivetted rim that fouled on the brake caliper.
