Results 1 to 10 of 13
Thread: Nanocom not reading
    DougLD Guest
    Nanocom not reading
    Hi All
    I have conected the nanocom to the Disco and read the engine faults and there was not any so i cleared the memory anyhow. Next I slected the abs slabs to read the faults on and the nanocom comes up with a message that it cannot connect to the ECU am i doing anthing wrong.
    Doug
    here
    You might need acc on......or off
    Aug 2009
    Athens - Greece
    I adjusted the sls height yestrday on a friends V8,for slabs-sls the key must be at IG-ON position (binnacle lights on)
    Cambewarra, NSW
    Hi Doug, you need the ignition on (position 2) with engine not running to reduce any noise interference.
    The Nanocom often has a communication problem when switching between ECUs. After reading/clearing engine faults disconnect the OBD lead from the Nanocom, plug it back in, then go to ABS SLABS and read/clear its faults.
    regards
    DougLD Guest
    Hi All
    Thanks Gary I will try this this afternoon i will keep playing with it so i get use to it when connected to the engine ecu it showed no faults. This would have to be the best forum around so much information and so many people willing to help out. Once i get the hang of hit it will be available for anyone to use on the Mid North Coast NSW.
    Doug
    here
    yep no probs....
    oh you said Gary
    Mar 2009
    Port Stephens N.S.W
    Hi Doug.
    Re the SLABS ECU ... I get best success reading/clearing by having the key at pos.1, run the Nanocom thru to the point of actually reading/clearing/writing, and just before you push the yes button, turn the key to pos.2, wait a few sec's, then hit yes.
    Kev..
    Kev..
    2014 Isuzu MUX LST with fruit
    2008 Isuzu D-Max
    2015 Kimberley Kamper "Classic"
    Gone ... 2004 D2a Td5 Auto "Classic Country" Vienna Green
    DougLD Guest
    Hi All
    Thanks to everyone for answering my query I tried it this afternoon and it read the slabs unit no problems at all. I have now tested the ECU and the Slabs ABS ECU and i have not got any recorded faults in either ECU. At least i am confident when we go on our trip to Lake Eyre next week i should be able to clear any faults that arise. Regards
    Doug
    Zute Guest
    Lake Eyre, you lucky SOG. wish I could go, I believe Coppers ck is about to flow into it and the South lake will start to fill soon.
    Williams West Aust
    I tried reading the SLABS on a D2a today.
    My Nanocom wouldnt have a bar of it,tried a few different methods as above.Works fine on my D2.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
