Results 1 to 6 of 6
Thread: DEFENDER 6SPD TO 300 TDI
    Jul 2010
    PERTH
    Does any one know if someone has put a new def 6spd box onto a 300tdi engine?
    Nov 2008
    would be a good combo, jsut a bell housing,, and the puma tcase, prity sure the mounts on the t case to chassis are the same, and the puma tunnel cover
    Jul 2003
    That would be an interesting experiment.
    Certainly the 6 speed is well matched to the Puma engine's characteristics.
    Whether the torque-over-rev-range delivered by the Tdi would suit the ratios is a question to be answered.
    The low first and then the jump to second might challenge the dull patch below 1800 rpm that the Tdi has. The Puma (turbo) pulls well from 1200 rpm.
    Mahn England
    Ex 300Tdi Disco:
    Bracken Ridge, Qld
    Waste of time and money.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    NW Tassie
    ^ X2
    You'll end up looking like those crabs with one extra large left arm!
    Anyone here tried the 4800rpm VE IP governor spring, or won't the block take the strain?
    Daz.
    Mazarron,Murcia, Spain
    Thumbs down Def 6SPD to 300 TDI
    One problem (challenge) is the bell housing is part of the box so would need an adapter housing (flywheel housing) making, how do you accomodate the extra length of gearbox this flywheel housing creates.
    Then what do you do about the clutch, new input shaft?? spud shaft?? . Don't forget the Tbox is rotated (clocked)10deg from the normal position.
    Not really a simple fix or we would have done it!!
    Food for thought.
    Ian Ashcroft
