Results 1 to 10 of 20
Thread: Air Conditioner Icing Up
    Scooter Guest
    I have had my defender since new from Nov 2008 and moved to Darwin in Sep 2009. From christmas 2009 the air conditioning system has been icing up.
    I have had the thermostate changed twice and recently the tx valve all under warranty but still the air con is icing up. Has any one else out there experienced the same problem or have any I advice I have lost all confidence with Landrover to fix this fault. It seems to be worse in humid conditions.
    Williams West Aust
    It isnt something real silly like blocked drains???? Sometime the simple issues are overlooked.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Western Victoria
    I had that problem with my Commodore. Check the condensate is draining quickly enough. If it's not, the vaporator gets immersed in the condensate and it freezes.
    Common
    Turn fan down 1 notch when it's humid.
    NSW far north coast
    As the fella's above have said, a coil ice up is usually the simple things.
    These problems are what can cause any refrigeration/air conditioning coil to ice up (and several have been 'fixed' on your car)
    Lack of air flow through evaporator. eg. fan motor failure, fan blade spinning on shaft, blockage, eg plastic bag sucked into the return air. (pretty common) ducting/shroud misaligned so air is by-passing coil, etc.
    Blocked drain, partially blocked drain, coil sitting in the drip tray (needs an air gap between water and coil or icing will result)
    Thermostat set too low cut out temp. Thermostat cut in temp too low. Thermostat points fused.
    TX valve being partially stuck shut causing an external ice up is pretty uncommon, usually the LP control will trip creating short cycling before that happens.
    Nov 2008
    very commen prob with the puma's, the way the air flows onto the evaporator is useless, if you sore it you'll no what i mean,
    and they let the ac get so cold so it works as good as it dose, but that has brought on this problem, the temp sensor on the evaporator needs to be set 1-2deg higher and it would fix the prob,
    I wish I could get mine cold...
    used to ice up till they fixed it couple years ago now it gets cool and on a long drive might as well noot have it on as it seems to cool nothing.
    Jul 2003
    Mine works very well.
    For all those that are critical just remember that this the first factory fitted Defender AC that comes within cooee's distance of the definition of Air Conditioning.
    Those prior to the Puma could also open the flaps and imagine.
    Seriously though with humid air try adjusting the temperature and fan speed. It might reduce the cooling effect but might also stop the moisture from condensating and freezing on the coil.
    Mahn England
    Ex 300Tdi Disco:
    Williams West Aust
    Open up your flaps Lou.
    I had a steer of The Grinch's Defer the other day,opened the flaps up NICE!!!!
    Pumas dont have flaps do they????
    Andrew
    Nov 2006
    Alice Springs, Australia
    I read my manual once it said that the aircon will drop the outside temp by 10 degrees in the cab. unfortunately after a long drive out here in the desert when the oat is 45,the cab structure is about 50 and i am happy when the aircon blows any kind of semi mild air at me
