Results 1 to 10 of 31
Thread: S 1, 2, 2a or 3.... Whats the difference?
    Jul 2010
    Mirboo North, Vic.
    16.28 MB
    I've had a bit of a look around to see if its been discussed before and couldn't find an answer so here goes......
    I've been looking for a Landy project, I had a 2a LWB 24 years ago and for the short time I had it I enjoyed it.
    The big question is what's the difference between a Series I, a Series II, Series IIa and a Series III?
    I'm not really interested in a County or Defender although I've played with them on behalf of mates who own them and I've got my Rangie anyway.
    I understand that they are leaf sprung which is fine by me and probably underpowered which is also fine.
    Lack of Synchromesh also doesn't bother me nor does lack of creature comforts and the vehicle will eventually become my daily hack about (I work on a farm).
    What im not into is Wide tyres with tread you could cram small kids between, Air con, power steering and 4 wheel drives that cant be hosed out and then driven if the need arises (P38's and Disco's spring to mind) and Doof doosh.
    I like Bar tread tyres, split rim's and slab sided utilitarian vehicles.
    So I gather Ive got 3 generations to choose from but the question is which best suits my application.
    My App.
    On and off road driving, light towing and some recovery.
    A motorised wheelbarrow for fencing and carting feed.
    I do look after my vehicles and try to keep them neat but they are far from trailer queens and get used.
    Your opinions please Ladys and Gents!
    Tony.
    Series 1 covers a wide range of changes to Landrovers. They all had flat sides, and the petrol ones had IOE engines, either 1.6 or 2.0l, with 2.0l diesel in 1957 an option. All had pedals through the floor, and all had headlights in the radiator support. The earliest were the 80" and these differ most from later ones, and also had the most production changes. Collectible, and some parts hard to find. These were replaced by the 86" and the 107" introduced. With very little change these went to 88 and 109". Probably the best option for Series 1. The 107" five door wagon is in many respects the most interesting, and quite rare.
    Series 2, although looking significantly different with a distinct waist and pendant pedals, is otherwise very similar to the last Series 1, except for the new 2.25 petrol engine, based on the diesel. Series 2a introduced the diesel upsized to 2.25, and marked the start of ongoing progressive change. 1967 saw a change to negative earth and cable operated wipers, key start, and other changes, and about then the six became an option. 1969 saw the headlights move to the mudguards, and the last Series 2a were in 1971.
    Series 3 is distinguished from Series 2a mainly by door hinges, windscreen hinges, a plastic grille and plastic dashboard, plus all synchro gearbox,and changes continued. 1979 saw the optional V8 and about 1981 the Isuzu diesel. Last Series 3 was 1983.
    My choice is the Series 2a. Note that most mechanical and body parts are interchangeable if not identical from first Series 2 to last Series 3, although traps for the unwary include changes from BSF/Whitworth to Unified threads, to metric threads - but the changeover was still incomplete by the end of Series 3, which still has a few BSF and Whitworth and a lot of UNF.
    Hope this helps.
    Jul 2010
    Mirboo North, Vic.
    16.28 MB
    John, what a pearler of a reply mate!
    So it looks like a SIIa or SIII because im not fond of + earth vehicles.
    The thread assortment doesn't bother me as most of my stuff is imperial anyway.
    So the focus is now on S 2a and S 3.
    Tony
    Quote Originally Posted by tony66_au View Post
    Tony
    Changing a positive earth Lndrover to negative earth takes about five minutes if you know what you are doing, perhaps fifteen if you have to follow instructions. I would not let this affect my choice! In any case almost all will have already been changed.
    Another point is that Series 3 have an alternator, not generator - but it is a bolt on change for Series 2/2a. Again, many will already have this.
    Jul 2010
    Mirboo North, Vic.
    16.28 MB
    I guess that any electrical work on a Landy would be minimally invasive anyway and Gen to Alt doesnt bother me because Ive had older cars in the past same as doing external reg conversions for alternators.
    Are Landies a full time four wheel drive?
    Landrovers were full time four wheel drive from their inception in 1948 to late 1953. From then until the end of Series 3 production, Series Landrovers were part time four wheel drive except for the V8 and Isuzu engined "Stage 1" Series 3 Landrovers from 1979 on.
    Rangerovers and Discoverys have always been full time four wheel drive. The 110, when first introduced in1983, had part time four wheel drive as an option but only with the four cylinder engine (not sold in Australia), although standard was full time, and most were sold this way. V8 and all Ninety and Defender Landrovers are full time four wheel drive.
    d@rk51d3 Guest
    Series vehicles are part time 4wd. It's engaged with the yellow knob, and disengaged with the red hi/low knob.
    Early s1's had a pull chain to engage 4wd.
    Jul 2008
    Lismore NSW
    series 3 (post 1978?) has inertia reel seat belts, this requiring engineers cert to remove roof or modify cab -pre 78 had different design regs (in NSW anyway)
    series3 would be my choice being a newer chassis,bulkhead etc-
    Also later series3 have a dual brake circut which can prove usefull when a stump rips off a brake line in a hilly paddock
    3's have a salsbury rear end in the 109 not sure about 2's
    Brett
    110 300tdi
    109 h/top
    Nov 2008
    Tony, I would say series three is the best value. You have the stronger salisbury rear in LWB models. They have had less years of neglect by virtue of their age. The gearbox is not good, but if money comes into it, these are hard to go past, unless of course you get lucky with an earlier model that has been respected.
    Quote Originally Posted by bcj View Post
    Brett
    110 300tdi
    109 h/top
    Salisbury rear axle was standard on Series 3 109s, optional on late S2a 109, but many S2a have been retrofitted with them.
    Another point worth noting - While the wheel stud pattern is the same on all Series Landrovers (and 90/110/Defender and RR Classic and Discovery 1), wheel studs were 9/16 BSF from 1948-1971, when they changed to 16mm. Studs are not interchangeable, but hubs are. Also, wheel bearing and stub axles changed about 1980.
    Series 3 in Australia almost all had fresh air heaters, earlier Landrovers had recirculating heaters if any, as they were optional from 1948.
