Results 1 to 6 of 6
Thread: Freelander will not start
    scout Guest
    Hi all, our Freelander will not start when it is hot if left for about 30minutes. When it cools down it starts OK and if started straight after stopping it also starts OK. It is a V6 Auto 2001 model. Assistance would be appreciated.
    Jul 2010
    PERTH
    Most common fix for this is the camshaft sensor
    Apr 2007
    Prospect SA
    Vapour lock in fuel line?
    Had similar in a V6 Rangie with commodore motor.
    Hunter Valley
    Quote Originally Posted by INDIE2002UK View Post
    X 2
    get the codes checked
    scout Guest
    Freelander won't start
    I will get the codes checked and see what that shows up. I did think it may be a bloked fuel filter, were are they in the 2001 V6 model and is there 1 or 2 and do they have 1 or 2 fuel pumps. Thanks for the imput
    Hunter Valley
    V6 only have 1 pump and 1 filter. The filter is part of the pump and is located in the tank. It can be replaced without replacing the whole pump. Part number WFL000010 is just for the filter element.
