Results 1 to 3 of 3
Thread: Spring over suspension
    Dec 2008
    Central Coast, NSW
    Ok,
    This is probabily an old question for some..........but, whats the Do's and
    Don't's for a spring over on the 2A...............all advise will be appreciated.
    Thanks in advanced
    Tony.
    thats easy...
    DONT.
    its hard on the springs, driveline angles and steering geometry and other than giving you better angles doesnt actually increase your clearance because the diffs are still down in the wheels.
    the articulation is no better UNLESS...
    you do a set of flat parabolics that you then do the spring over conversion on..
    with the right set of paras over the axle you get some good flex and clearance and the vehicle still looks more or less the same from the outside.
    Dec 2009
    Queensland (though occasionally elsewhere)
    Why would anybody want to be like a yucky Hilux?
