Results 1 to 4 of 4
Thread: Carmtrol LPG Cutoff
    Rosevale, Qld (south of the 'Switch)
    Question Carmtrol LPG Cutoff
    Greetings gurus!
    Does anyone know anything about Carmtrol LPG cutoff switches?
    My LPG isn't switching over from petrol. Yep the flick switch works and has power running through it but when it gets to the Carmtrol (CARM00) the LPG Valve has minimal voltage. Does anyone know how much is supposed to flow through to the valve?
    Here's a diagram I found on a Torana site - different model Carm but same layout/concept (to help see what I mean).
    Maybe the unit needs to be replaced but obvioulsy I want to check everything else before replacing it.
    If I do need to go down that route, what are the unit recommendations?
    TIA
    Stu
    Stu
    1993 Range Rover Vogue SE 3.9lt - languishing
    2 x 1981 3.5lt V8 2dr Range Rover
    1958 Series 1 109" - "Bob" - COVID project
    Who wants another politician as Head of State? Not me:
    http://www.monarchist.org.au/
    Crafers West South Australia
    The Carmtrol safety cut-out is an ANTIQUE!!!. I used to find them reliable at 1 amp, touchy at 2 amp load, and blow up rapidly at 3+ amps. I haven't used one since the mid 90's. Nowadays I use the Apexus CO100 (or CO101 on EFI cars) which seems to handle 5 amps with ease. Rarely give me trouble. Try your local gas fitter or Welcome to the APEXUS Pty. Ltd. World Wide Web Site. Trade is about $25.
    Wheelers Hill, Melbourne
    I'm pretty sure I had one of these & the trouble I was having was similar & turned out it was a faulty earth.
    Thanks guys.
    Yeah, I thought of the Earth side of things, then got distracted. I'll check that out, otherwise, it doesn't sound to heavy on the wallet to replace.
    Stu
