Results 1 to 10 of 11
Thread: Windscreen Wipers rubber blades
    matthew2 Guest
    HI ALL
    I own a 2001 defender and the wiper blades are CRAP they fall apart easily and don't clean the window properly . Is there a another type of after market rubber blades on the market that I can use ??
    Western Victoria
    I have used all sorts and have found Trico to be the most consistent in quality.
    Also, check the springs are putting adequate blade pressure on the screen.
    P38ace Guest
    http://www.silblade.com/
    These are reported to be the best available. Have not tried them personally yet but will be getting some for the new 110 when it arrives.
    Jul 2007
    Melbourne, VIC
    The part number for the wiper blade assembly is DKC000110PMD. Britpart supply an aftermarket one but I have found that the original L/R part fits the wiper arm much better and clears the screen well, although it is quite a bit dearer than the Britpart one!
    If the wiper arm spring is weak it can also mean streaking across the screen so if it needs replacing the part number for just the wiper arm is PRC4276-B. I fitted a set of aftermarket ones and they were very good quality and improved clearing rain noticably.
    Blades can be fitted without replacing the wiper blade assembly but they are a bit fiddly to get in and the wiper blade support can wear significantly meaning improper tension across the blade.
    I hope this helps
    VladTepes's Avatar
    Bracken Ridge, Qld
    Which aftermarket ones did you fit ? Would you do so again?
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Mar 2009
    Derbyshire UK
    Quote Originally Posted by P38ace View Post
    wiper blades, installation, auto, DIY, do it yourself, how to install, instructions, automotive from SPE - Specialty Products Enterprise, LLC
    have had silblades for six months and they do work
    dmdigital's Avatar
    Grockle where's a cheap place to get them from? They seem to come in at about £12 each which is expensive for wiper blades over here.
    Mar 2009
    Derbyshire UK
    na then Derek,hope ya feeling better,I got mine from Mudstuff (+441422 881951)they aren't cheap as you say,but I think there worth it, £14.46 ex vat each
    VladTepes's Avatar
    Bracken Ridge, Qld
    I ave some of the plastic backled rubber ones from supacrap - will these fit - at least as an interim measure? Are Defenders needing 6 or 8mm width.
    gone
    1996 Discovery 1
    current
    Jul 2007
    Melbourne, VIC
    Quote Originally Posted by VladTepes View Post
    From memory its 6mm.
