If you have four inches of free play - you need to find out where it is (could be a lot of little bits). Get someone to waggle the wheel while you look for it in all the places Diana suggested. There should be no more than about an inch on the rim of the wheel. If all your play is in the steering box (which is the only place in the steering linkage where there should be any play, then the box needs overhauling if it cannot be removed by adjustment.
Other points to check, not mentioned, are anything that is "springing" when you move the wheel. This could be the bulkead where it steadies the steering box support, for example, or a bent drag link, or tie rod ends that are not aligned from end to end of the drag link or tie rod.
Oh, and the only reason you would consider wedges is if the caster had been upset by fitting extended shackles without extended spring hangers - and you probably would not get that engineered anyway!
					Reason: Back to the original question!
