Results 1 to 10 of 14
Thread: Uploading/resizing scanned files
    NSW far north coast
    I was going to PM a Mod, but thought I'd put it out to everyone.
    I've scanned some pages from an old Maxi Drive catalogue that lists a heap of LT230 t/case data and initially saved them as bitmaps.
    I've also saved them as JPEG's but either form is frigging huge.
    I'm a bit of a numpty with this computer stuff (sorry to The Numpties ) and don't posses a PDF converter, (I'm pretty sure, although I might have an old version of Solid Works here somewhere) so what's the easiest way to convert them to a reasonable size so i can upload them as a reference ?
    Feb 2010
    Supine
    Do you have word '07 mate?
    or PDF Converter - Convert to PDF Online Free
    NSW far north coast
    Naa, Open Office.
    Maybe there's something in there ?
    I'll have a looks see.
    Feb 2010
    Supine
    The link above should do it...says it does convert open office to pdf...
    CutePDFwriter is another solution. It does not require you upload large files to a web page. CutePDF But note, you will need to install the Ghostscript converter first as detailed on the CutePDF web page.
    However, if you can scan and save them to Jpeg format at the moment then why don't you just scan and save them to Jpeg using a higher compression rate if you want the file size to be smaller.
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Jun 2008
    McMinns Lagoon NT
    PDF Creator is another one. I would say it should be OK with Open Office but have not tried it.
    Download | pdfforge.org
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Open Office converts to PDF perfectly for me.
    File/Export as PDF...
    I have PDF Creator here at home and CutePDF at work. By far, CutePDF is far easier as it comes up as a printer and you just save it all within the bounds of a normal filesave in windows.
    PDF Creator requires more input for the same result and takes a lot longer to complete.
    Andrew
    Have a look online for cc pdf. Works a treat.
    Jul 2009
    Mid North Coast, NSW
    287.34 MB
    as mentioned open offic has great export to pdf function, but jpgs would also be ok if that is too much work.
    they will not be too big if you resize them. what they will have been scanned in at wil be overkill.
    just zoom all the way out till all bits are still readable in size. then resize to that percentage.
