Thread: Fuel Tank Sender Unit???
    Jan 2009
    Eatons Hill, QLD
    Question Fuel Tank Sender Unit???
    Hi,
    Hoping someone could help with a small wiring issue. I have a 2009 Defender and need the specifications for the fuel sender (Ohms for full and empty tank conditions). I have a subsciption to the GTR but they have optioned to leave this bit out. Any help would be greatly appreciated!
    Thanks, Bender
    Jul 2003
    Can I be nosey and ask why and what the issue is?
    Mahn England
    Ex 300Tdi Disco:
    Jan 2009
    Eatons Hill, QLD
    Fixing the things Ford got wrong.
    I guess you have a 08 Defender
    In short, I had to replace my instrument cluster as the tacho and temp gauge operate via CAN bus and won't work with the few mod's I have done since I bought the car. See Link,
    [nomedia="http://www.youtube.com/watch?v=MRe81ALrI98"]YouTube- ‪2009 Land Rover Defender LS2 V8 Conversion.‬‎[/nomedia]
    I case you are wondering why, I have a 1000 reasons why Ford should have dropped the Defender from its range before they could afford more than the $10 and 20 minutes they spent downgrading to the Puma
    Cheer's, Tristan.
    Jul 2003
    So it's not a LRA-denying-warranty-cover issue then....
    Here I was thinking that you'd filled the tank using a Hi flow pump causing the float to remain submerged hence a low reading on the guage
    Make our day tell us more about the mods and don't spare the detail.
    As for the ohms its no wonder there is some resistance . Most of the detail contained in the GTR is non existant.
    Mahn England
    Ex 300Tdi Disco:
    Jan 2009
    Eatons Hill, QLD
    What Warranty!
    Yeh, warranty! Anyway, LR have agreed to re-spray the roof (cracked paint). Beyond that, well I imagine a siren sounds somewhere at LRA when the dealer mentions my rego' number.
    Detail,
    307kw 6.0l LS2
    Flappy Paddle - 4L65e (auto with manual control option)(Commodore SV6 wheel)
    80 series t-case
    Remote Start
    PWR radiator (SPAL fan)
    P38 power steer box (coming)
    VE Commodore engine ancillaries
    Auto Meter Instruments (not by choice)
    Dash-Daq
    Automated transfer case (H/L & 4WD) Pnematic
    GU Axles (very soon)
    Lockers
    LR Fuel Tank (145l)
    Land Cruiser prop shafts (modified)
    HID's
    Other random 4x4 stuff
    Half finished rock sliders
    OME suspension (standard height)
    That's the most of it.
    Cheer's, Tristan.
    Williams West Aust
    Makes the story of the cancellation of a Puma warrantty due to aftermarket shocks causing persistant rear diff failures pail into insignificance.
    GO HARD
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Jan 2009
    Eatons Hill, QLD
    FSender???
    Hi,
    I guess I'm going to have to measure these values the old fashion way. I'll post them once I work it out, incase someone wants them in the future.
    Thanks, Tristan
    Jan 2009
    Eatons Hill, QLD
    2009 Land Rover Fuel Level Sender Values
    Measured
    8 ohms - Full
    320 ohms - Empty
    Williams West Aust
    Bender.
    Would be great to see some pics of your beast in "members rides"
    Andrew
    VladTepes's Avatar
    Bracken Ridge, Qld
    It would !
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
