Results 1 to 4 of 4
Thread: Engine to bellhousing bolts
    Geelong, VIC
    Can anyone confirm what the thread is for Isuzu LT95 bellhousing to engine adaptor bolts.
    10mm x1.5 is the only size that I have that threads in nicely, but even that feels just a fraction loose.
    While I'm asking - are they fitted with spring washers, or just plain ones and maybe a bit of thread lock.
    Steve
    Hay Point
    Quote Originally Posted by steveG View Post
    Steve
    Steve, 10 X 40mm medium grade bolts with spring washers is all I can find in my manuals. They fit through the flywheel housing and thread into the alloy clutch bellhousing. I have done a few of these over the years and have never used loctite and have none come loose. Sorry I cant help with the pitch size but if they screw into the alloy housing ok that would be it as its quite a deep thread.
    Cheers......Brian
    1985 110 V8 County
    Geelong, VIC
    Thanks Brian - exactly what I was after.
    Which manual shows these sort of things best? I've got the Isuzu engine manual, the 110 manual, but nothing Isuzu-110 specific.
    Steve
    Hay Point
    An army 110 RPS (repair parts scale) is what you need. Covers part numbers for the perentie, there are several variants but the mechanicals are basically all identical.
    Cheers......Brian
    1985 110 V8 County
