Results 1 to 10 of 12
Thread: I love this thing.....
    Bracken Ridge, Qld
    I know Inc won't beleive it but..
    I set about fitting the Mud Pod with the switches etc. Got as far (today) as fitting the cigar lighters (for power sockets) - what a PITA.
    Anyway it said to drill a 28mm hole so I went and got my holesaws and... 31 mm is the smallest. Typical.
    So, I wondered, how am I going to do this... I drilled out as big a hole as I could with my bits, expanded it slightly with an old round rasp.. enough so that I could then fit in a sanding disc on my... DREMEL TOOL.
    (The Dremel was a gift from my missus and I have never used one before).
    What can I say.... I love it. I think I may become addicted and have to start cutting and grinding and...
    Now I just have to work out what all the thingies that came with it do. Some are obviously for grinding, some cutting, some sanding, some mystery items....
    Cool.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Goolwa SA - but top ender forever
    I was given one as a present as well i used it to cut all the rust out of my suzuki so I could then weld in new panels it is a finesse tool not a powerful tool.
    I love it as well
    Jun 2010
    Fremantle
    I used to think they were silly toys untill I had the need to use one, now I think they are great. Attachments for every job
    03 Disco 2a, TD5, Olso blue, 7 seater, Auto, Chipped, EGR'd, 2"lift, SLS, Dual Batteries, Provent, TM-2 engine saver
    Feb 2009
    A bloke's Bamix. Great tools.
    KarlB
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    Quote Originally Posted by VladTepes View Post
    I know Inc won't believe it but..
    your right
    i don't!
    who plugged it in for you?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Jan 2010
    Tamworth
    I would have been stuffed if not for the dremil with a tiny dye grinder bit , when i snaped a drill bit off in a broken exaust manifold stud. Bloody briliant tools.
    Quote Originally Posted by incisor View Post
    your right
    i don't!
    Yes and now three of his fingers are an inch shorter ....
    2011 Range Rover Sport SDV6 Autobiography
    2004 Freelander TD4 SE
    1997 Range Rover 4.6 HSE
    1994 Range Rover Vogue
    Bracken Ridge, Qld
    All I need to know s what all the tools / bits etc that came with it are for !
    gone
    1996 Discovery 1
    current
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    shortening fingers, they tell me.....
    I first saw one in Jakarta in the early '70s when visiting an ex-colleague who was into model trains.
    When I came home I bought one (being an aeromodeller and model boater).
    Boy, has mine seen some use over the past 35+ years.
