Results 1 to 10 of 30
Thread: Electric chainsaw sharpeners
    Williams West Aust
    Hi Guys
    Time for another chainsaw topic.
    I have an electric chainsaw sharpener on its way.
    Its the cheapo chinese type,the more expensive of the 2 that star on Ebay(Oregon commercial copy)
    I would love input from those chainsaw lovers that have used them.We actually have an Oregon sharpener at work bolted to a bench.It isnt used as nobody has ever been able/taken the time to set it up.(disc hasnt even been dressed to the correct profile)We have a jig file expert that keeps the chains in excellent condition as long as nobody else touches them so the machine is dormant.
    I have the settings reccomended to me by the bloke who sold me his Husky XP120.
    Im setting my sharpener up just like his.
    Wheel rim base on the floor,easy to roll it out of the way when not in use.Pipe stem with a mounting plate so all the grinding is done standing up at eye level.Bolts are welded to the stem to hang chains on.
    Yes once I get it and set it up I will post pics.
    Yes all PPE will be used
    All input will be enjoyed!!!
    ENJOY
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    RIVERLAND, SOUTH AUSTRALIA
    ive only had petrol chainsaws....
    with them you sharpen the chain not the whole chainsaw.... obviously electric chainsaws are different??
    (no I still use a file, sorry I couldnt resist! )
    NSW far north coast
    Andy, I've never used a cheap grinder ([edit] any grinder ) but those who's advice I value reckon don't bother, particularly after you've used a decent one
    I can also advise not to get a Maxx grinder, my mate Matt had one and eventually ebayed it, it wouldn't hold consistent angles.
    He bought a Speed Sharp instead (Tecomec/Precision Tooling, the manufacturer of the Oregon ones) and loves it.
    His business is chain sharpening, accessories, tools and tree felling.
    Stick with the Tecomec/Precision Tooling/(Speed Sharp, Jolly, etc)/Oregon ones.
    You pay for them but all the fella's I talk to reckon this is one time it pays to fork out the $ for a decent one.
    I can give you Matt's phone # or email and you can have a talk to him, he's bloody good on his prices too, he freights stuff to me from South Oz.
    Apr 2010
    Ascot Vale, Melbourne
    I use a file. Takes me a bit longer than perhaps a leccy sharpener would, but does a far better job IMO.
    NSW far north coast
    Quote Originally Posted by chris_mack View Post
    A well setup grinder with a well shaped wheel (or better still an ABN/CBN wheel but they are $$) and someone with a light hand does a good job and if you have a lot of chains to sharpen or have one that's been rocked or even just been cutting abrasive stuff I can see the advantage in having a grinder around.
    Mar 2007
    South Arm, Tasmania
    I've got an oregon electric sharpener in the shed. Never use it.
    Found that when I did use it years ago, could never really get a consistent angle and the saw always cut in a curve. Also, chains never seemed to last as long - probably as a result of using it more than would normally have been necessary in order to correct my stuff-ups and me being heavy handed.
    These days, it's always just a file and the bench vice for me.
    Which reminds me - I'd better get it out this afternoon. There's a pile of stuff up the back that needs cutting and I've been putting it off. But wet weather is forecast for here for most of the week, so if I don't do it today .................
    Cheers .........
    BMKAL
    Nov 2006
    cardiff ,NEWCASTLE.
    Quote Originally Posted by digger View Post
    1969 LWB S2a yellow, gone
    1972 LWB S2a 5 DOOR wagon coming & GONE
    1973 LWB S3 green Sadly GONE
    1977 LWB S3 tabletop building
    1992 disco BOINGY BOINGY
    My landrover doesn't leak oil , IT SWEATS POWER
    JASON & KAREN
    briz
    hi i got a cheap ebay one as well still learning how to use it i have found that the chain does not stay sharp for long. have a look on u tube few vids on how to do it but if anyone has any tips that would be great.
    Mar 2009
    Port Stephens N.S.W
    BMKal ... if it's not cutting straight, your bar rails need re-levelling ... it's not the chains fault !
    Andy, get the manufacturers specified angles for the chain and be particular in setting up the machine first ... should only have to kiss the cutters to get an edge back ... I flip a new chain on as soon as the one in use looses it's edge ... most folks keep going, and you round the leading edge (top) of the cutter down, requiring more cutter ground off to get the right angle .... good way to go through chains.
    ... and, chip away at the cutter in lots of little up/down strokes, don't just sink the wheel into the chain in one fell swoop ... you'll soften the cutter and it won't hold its edge ... it'll turn blue, and it's rooted! ... some cheaper chains I've had in for sharpening blue way too easily ... crap chinese chain!
    Kev..
    2014 Isuzu MUX LST with fruit
    2008 Isuzu D-Max
    2015 Kimberley Kamper "Classic"
    Gone ... 2004 D2a Td5 Auto "Classic Country" Vienna Green
    NSW far north coast
    Quote Originally Posted by Fluids View Post
    Good advise as usual
