Results 1 to 10 of 11
Thread: Will 4.6 heads bolt onto a 3.9 block?
    ChCh New Zealand
    As the title really.
    Will 4.6 heads (P38) bolt onto a 3.9 (96 Disco) block?
    Kingston, Tassie, OZ.
    Yes.
    JC
    ChCh New Zealand
    Thanks for the quick reply,
    I thought they would, but just read something that put a bit of doubt in my mind.
    Avoca Beach
    But best with composite gaskets.
    Regard sPhilip A
    They may not have the holes for the 4 outer bolts. Mine don't but my 4.6 block has holes for the bolts (which it shouldn't have).
    96 D1 hasn't got the outer bolt holes in the heads either. Most Early non Serpentine belt 3.9's (pre 'MA' VIN) in early D1 and RRC did have the extra row of bolts.
    JC
    Brisneyland once again
    Quote Originally Posted by Siska View Post
    what gains are going to come from the swap??????? Valve size larger???? better flowing heads???
    Doesn't the 4.6 have a bigger chamber capacity than pre serpentine 3.9's????
    This is going to drop the compression from the already low 8.13:1 on the 38D engines.
    Andrew
    Quote Originally Posted by LOVEMYRANGIE View Post
    No .
    G`day , as said they will fit without problem .
    What`s not said is , if you look at the casting numbers in this case you will find the reason they will fit is that they are the same thing .
