17th August 2010, 06:11 PM
90 RRC (and D1?) Clutch
Hi all,
The clutch pedal on my 90RRC is feeling very strange. There's about 30mm of free travel before the hydraulics kick in. The bite point hasn't changed but overall travel is short and abrupt - lost its springy overcentre feel.
There's no clutch slip or judder, and the reservoir isn't loosing fluid.
Prior to this the action felt very "dry" at the top of travel so I suspect seals and dirty(old) fluid. I know the clutch can be tricky to bleed - can anyone recommend a reasonably priced vac or pressure bleeder??? (I've got to do this on my own)
Worst case it's the clutch/pressure plate. Which is not unreasonable as its got 200k on it. Is there any way of checking clutch wear without splitting box and motor?
thanks
Chris
