Results 1 to 10 of 13
Thread: Gets hot in cabin with windows down
    MacLeith Guest
    Hey all,
    Something that's been bugging me for a bit, just wandered if there's an obvious cause/fix. Have a 1995 Disco V8 manual.
    If drive about with the windows down the centre consul gets very hot along with the footwell and eventually the whole cabin. With the windows up this doesn't seem an issue. But generally need the aircon on instead as kinda hot up here.
    Any clues?
    Mac
    Douglas Park, NSW
    With the windows down, you're allowing airflow through the cabin.
    Maybe this airflow is sucking up some heat from somewhere on it's way into the cabin.
    With the windows up, you're not getting a through flow of air, therefore no hot air is getting in.
    MacLeith Guest
    Thanks Scouse,
    Yeah I had sort of guessed that it was pulling in engine heat. This the second mid nineties Disco I had that has this "issue" I suppose I was really being lazy and hoping someone else had flagged it as a problem and sorted it out. Reckon I should be looking for missing grommets/inserts or gaskets in the firewall or transmission tunnel.
    MacLeith Guest
    Looks like there is a big rubber insert under the consul through which the gear lever goes, it has holes in it that look Iike screw holes, but there are none there. Should there be a plate or bracket that holds the thing down, just putting screws in doesn't look like it would make a good seal.
    Aug 2010
    Sunbury, VIC
    Wish I could get the cabin of my RRC to heat up like your Disco - Down here in Melbourne we could use a bit of warmth at the moment...
    Jul 2010
    PERTH
    i had something simular where the centre console would heat up by rh side i traced it the the foam around the heater matrix where it slots in had come adrift so the air was blowing striaght out the side and not throught the heater assy, this was causing the console by the cigar lighter to heat up even melted a bic pin
    Douglas Park, NSW
    Quote Originally Posted by MacLeith View Post
    There's a retainer plate that sits on top of that & is riveted to the floor.
    MacLeith Guest
    Thanks Scouse,
    I guess that's it, at some point this engine has been out of the truck, if the plate is riveted it may have been left off. I know my las truck had a recon engine and the same issue.
    Apr 2007
    near the barrossa
    Is it just the climate control being on, with the windows down if it is cooler outside than in the climate control will try (very hard) to heat the cabin up, starting from the bottom vents this will heat up the console and foot wells???
    Cheers Keith
    Douglas Park, NSW
    Quote Originally Posted by keith View Post
    Nothing like that in a D1 .
