Results 1 to 6 of 6
Thread: Fuel injecting 3.5 v8 1986
    Mar 2009
    Right lads, I am fitting a fuel injection system off an 1986 R/R to my 1981 3.5 Stage 1. Problem is the wiring harness does not seem to match the AFM (supposedly 88 R/R). The harness has a 7 pin plug whereas the AFM has a five pin plug. Can the two systems be wired together, ie: lose two wires from the 7 pin plug or can the plug on the AFM be changed to a 7 pin plug? Need help ASAP as this is my work vehicle and I have jobs awaiting and cash to collect.
    Thanks.
    Freestyler Guest
    Sounds like you have a hot wire EFI harness and the flapper sensor. They cannot be hooked together as the sensors on the earlyer flapper type Monifold are different. The hot wire one is a better one though
    Tim
    Avoca Beach
    Sounds the other way around to me.
    The MAF only has 4 wires.
    I think you have a MAF not a flapper.
    The correct air flow sensor has a flap inside which you can see by looking in, while the MAF (wrong) has a screen on the front and just a hole in it with a small hole on one side.
    Look in markets to see a photo.
    Regards Philip A
    Mar 2009
    afm-maf
    so mate could you post pics to kenmead@dragnet.com.au
    so I know what I`m looking at
    thanks steve
    Avoca Beach
    Look here and you will see the wrong one.
    Rover 14CUX Hot Wire Mass Flow EFI: Service and Troubleshooting
    Regards Philip A
    Mar 2009
    afm
    got that to print thanks
    my harness has 7 pins & meter has 5 pins
    would u know part number for the 7 pin air flow meter
