19th August 2010, 04:35 PM
Lake Eyre Trip preparation
Hi all, just getting my D1 ready for a 4500km to Lake Eye via Camerons Corner/Merty Merty/Lyndhust/Marree/Birdsville. The other couple we were going with have pulled out - so this will be a solo trip - just my wife and myself. The other vehicle was a Prado, so it will probably be better I we won't be constantly stopping to pull them out of puddles and be fixing their truck
So far I have stripped out the back seats, removed the heavy drawer system etc to reduce the weight. I've moved the cargo barrier forward and will build a light weight aluminium/cubelock frame to hold the jerry cans for water and diesel and will add tie downs to hold the rest of the gear in place. I will have a roof top tent, and a second spare wheel on an half size roof rack on the roof. I'll have all the necessary recovery gear, winch, maxtraxs, Hi lift, ground anchor etc. Spares include a full set of hoses, two fanbelts, pulley bearings and fan belt tensioner, water pump, filters, oil, transmission fluid.
The truck has 360,000km on it, but I replaced most of the drive train - less than 100,000km on it and most of the suspension has only 20,000km on it . Timing belt has been done 5000km ago, I've just fitted a Allysport header tank (more on that in another thread) Bilsteins and BFG KM2's.
I will carry a UHF, sat phone, EPIRB, and will be tracked by our Securatrak system by the guys back in the office - testing out the new satellite link system for remote area travel that updates our location every 15 minutes and have a "man down" trigger as well.
What are the usual suspects as far as breakdowns are concerned that I should be looking at?
19th August 2010, 04:53 PM
Main issues I guess are tyres, but with a second spare you should be fine.
If your D1 is in good mechanical condition I can't see you having many issues, just comes down to maintainence, take spare hoses as a precaution and the usual fluids.
I have just returned from a trip up the birdsville track and there is plenty of water around which made for some fun, the track was well rutted but pretty good in all but a few areas, just watch out for the washaways and dips as my suspension didn't like them much.
It is beautiful up (or down?) there, just enjoy your trip.
19th August 2010, 07:41 PM
spare hoses, spare belts, tyre repair kit. I also carry a spare bearing for the idler pulleys (tdi300), only break down part I have used along with the belt.
Brake fluid and a pair of multi grips for blanking off a set of brakes (had a gibber through up onto my brake line and snapped it off at the feral nut and did most of the birdsville track with no brakes.
have fun
blaze
19th August 2010, 07:49 PM
#4
anyone with a d2 td5 doing this trip is well advised to:- . 1....secure the heater hose at bottom of radiator so it doesn't get cut by the fan blade!. . .2....instal one of the electronic temperature monitoring devices that typically bolt to the block or head and have an audible alarm. I KNOW !!!!!!!
19th August 2010, 08:00 PM
#5
sounds like you are well prepared, take it easy and all should be right
my heater matrix failed, make sure you keep the coolant running through the engine i.e. do not blank off both hoses and i'm guessing you have an auto so need to carry a clutch master cylinder
19th August 2010, 08:47 PM
#6
Thanks guys - I'll add brake fluid to the list I have some spare brake hoses when I replaced the lot after the suspension change.
19th August 2010, 10:07 PM
#7
Iain
I don't want to hijack your thread, but we are heading out from Brisbane to Cameron's Corner then up to Innamincka and Birdsville on the 20th September.
Don't know if that coincides with your timing, but it would be nice to know who else is in the area at that time.
20th August 2010, 12:07 AM
#8
do a search on AULRO for "CLAYTON SPA", make it an overnight stop...its a great addition to a camp site!
theres lots of other stuff to see...mungerannie, etc etc...if you have seen the 'BACK OF BEYOND" movie its not too hard to visit half or more of the sites they call into! depends on your interests...
check out GEOCACHE or GEOCACHING - fun way to see things you'd normally miss. and a fair good number up that way.
Enjoy your trip, give someone your itinery (<= sp?) and if you are late/missing etc leave them the local police/ses numbers so they can call for help on your behalf,,Police dont monitor trps now due to so many ignorant bastards advising theyre going etc but not advising they made it,hence searches with police, ses, station people, townsfolk etc until confirmed they were OK somewhere sipping lattes (bastards!)
Enjoy your trip... Dont go off road where there is no established track and even walk that first as if its slightly wet you can sink and pan the car!. I learned this the hard way about 20 years ago, walking 20+ kms into Oodna!
(3' taller because of the clogging mud on my boots)
digger
(REMLR 235/MVCA 9) 80" -'49.(RUST), -'50 & '52. (53-parts) 88" -57 s1, -'63 -s2a -GS x 2-"Horrie"-112-769, "Vet"-112-429(-Vietnam-PRE 1ATF '65) ('66, s2a-as UN CIVPOL), Hans '73- s3 109" '56 s1 x2
77- s3 van (gone)& '12- 110
20th August 2010, 02:06 AM
#9
Do you really need to carry extra fuel ? Weight is your biggest enermy. On my last trip across the Simpson, we passed a nummber of D1's which had broken springs. They where very over loaded. Had every spare including the kitchen sink. If you've fixed every thing thats might break, than you shouldnt need a spare. Leave it with someone who can post it out overnite express if need be.
20th August 2010, 10:22 AM
#10
I thought about leaving the jerry cans behind, I've not driven in that area, so not sure what the distance between fuel stops is. I can do around 600km easily in heavy conditions, 800-900 on the open road.
Good idea about the spares - but posting them out will need me to be at a station or settlement - not much help if I break down in the middle of nowhere.
Our trip is from the 9th to the 19th - we want to be on the way back when the schools close.
