Thread: Need help for series distributor
    Jun 2008
    Morpeth NSW
    Hello everyone,
    I am not sure if this is a common issue, but here goes.
    I replaced the points, condensor, rotor button and cap on my '71 2.25 a couple of days ago. I didn't have a feeler gauge, so tried to set my gap by eye.
    After everything was done, the best i could do was have the car running very rough. Okay, no worries I thought. My gap isn't correct. Off I went today to get a feeler gauge and 'do it right'. I set the gap with the gauge, but the car was idling quite rough.
    So, I replaced all the new stuff with the old stuff, set my gap, but still had the same result.
    Question is, have I ruined my timing? During all this time I dropped something small under the advance bit twice, but managed to get it out without too much trouble.
    Any help would be great.
    Sam
    Douglas Park, NSW
    I assume you've double checked that the HT leads are in the right order.
    Also, how does the engine bay look at night with the engine running? Any stray sparks will show up easily.
    Timing being out does not usually make it run rough, and the fact that it starts and runs means the timing is not too far out. Similarly, the gap being incorrect, as long as it is somewhere near right, should not make it run rough - the symptom there would be hard starting, miss at high rpm, hesitation when putting the foot down, that sort of thing rather than rough running.
    I suggest you probably have damaged the connection at one end of one or more of the ignition high tension leads. Other possibilities include that you have cracked the distributor cap or rotor button.
    Less likely is a loose connection somewhere, possibly on the lead between the breaker plate and the distributor body.
    Hope this helps.
    Jun 2008
    Morpeth NSW
    I am 99% sure...
    That right?
    I had the bonnet off in the dark and didnt see any crazy sparks...
    Douglas Park, NSW
    No, I would have thought that it would have been 1 3 4 2, not 1 2 3 4 or 1 4 3 2 depending on your dizzy rotation.
    Jun 2008
    Morpeth NSW
    Cap and button are fine, I will have a closer look at the HT leads. Cheers.
    Douglas Park, NSW
    If your distributor looks like this (with the advance mech set the same):
    http://www.hollandrover.co.uk/distributor-erc6986-land-rover-series-2-2a-3-214-p.asp
    then you've set the firing order as 1 2 3 4.
    If you've marked #1 & know that's right, then swap the rest around.
    If you're not sure where #1 is, pull out the plugs & turn the motor over by hand with a thumb or piece of rag over #1. When you feel the compression, see where the rotor button is pointing - that's #1.
    Just to confirm, correct firing order is 1-3-4-2. Distributor rotates anticlockwise viewed from above.
    Hope I have that right!
    Jun 2008
    Morpeth NSW
    Thanks both of you. I thought I had it right... not the first time hehe. but will have a fiddle around soon and see what happens.
    Thanks again.
    Sam
    Jun 2008
    Morpeth NSW
    problem easily solved, thanks guys. My leads were in the wrong order. I just somehow got it in my head they where in direct order.
    On the plus side, at least i got some good practice at changing and setting my points, and it gave me a decent excuse to have a peer through the dizzy.
    Thanks again.
    Sam
