No the hand brake would be a bad idea its transmission mounted and not designed to pull the vehicle up.
I cant answer your question though usually they were towed behind graders and the like and it didn't matter.
G'day All,
Has anyone had any experience with setting up a breaking system for a S2A while being towed by an A-Frame.
I have the design for the A-Frame etc but as the S2a is obviously over 750kg, not sure how to provide breaking, maybe an enertia overide on the A-Frame connected to the handbreak???
Any ideas welcome.
Ben
I see what you mean djam1, but I must admit that I've used the handbreak to pull me up on a few occasions when the standard S2A "braking" system was "broken"
And thanks for the "spelin" lesson disco2hse
Ben
This will get you started
http://www.aulro.com/afvb/trailers-v...me-towing.html
Towing With an A-Frame
Thanks for the links Garry. Plenty to ponder!
I think as you say that it would probably a lot "easier" legally to use a trailer, it's just that the A-Frame principal is so simple:
It's just the issue of being able to activate the brakes in the towed vehicle from the towing vehicle??? This seems to be the biggest hurdle.
- No extra cost of purchase / rego for a trailer
- Less weight on the towing vehicle
- No problems of where to park/store the trailer at the end use point
- Being able to dismantle the A-Frame and take it with you in case of a breakdown etc.
Ben
You need to have the towed vehicle registered and there need to be lights on the back. A long cable and lights bar like boaties use is good for this.
Adapting an electric actuator to the brake would be the fun part. At least you can then plan a break-away system where the towed vehicle battery operates the actuator in event of failure of the A frame.
There are plenty of motor homes driving around towing suzukis on A frames - so there must be commercially available equipment to activate the brakes - they cannot all be bodged jobs.
Maybe check with the Winnebago company for their advice.
This answers the brake issue - override brakes up too 200kg and I assume electric for heavier vehicles. http://www.hitchngo.com.au/faqs.htm
