Results 1 to 8 of 8
Thread: Puma fuse location indicators
    Oct 2007
    G'day All
    The trailer electrical connector got damaged yesterday and the indicators (both) don't work today, so I suspect a fuse has blown.
    The owners manual doesn't identify a fuse for the indicators (2007 Puma 110). Can anyone help with identification of the fuse here please?
    Thanks in advance
    Brid
    Jul 2003
    If you open the cover to the fuse compartment located beneath the steering wheel you should see on it a diagram showing the location of the fuses and what they serve.
    (From memory there are two fuses for the indicators)
    Mahn England
    Ex 300Tdi Disco:
    Oct 2007
    Thanks Mahn
    Both fuses are fine...I am now wondering if the flasher relay unit may have failed instead.
    Jul 2003
    Do your indicators work with the hazard function activated?
    Mahn England
    Ex 300Tdi Disco:
    Oct 2007
    Yes Mahn, they do.
    Jul 2003
    Brid,
    sounds like the indicator flasher relay then?
    Mahn England
    Ex 300Tdi Disco:
    Jul 2003
    Brid,
    I'm not so sure about this now...I thought that the Hazards had a seperate relay. I've just had a look at the wiring diagrams for external lighting (attached) and my scalp hurts from scratching...see what you make of it.
    Attached Files Attached Files
    Mahn England
    Ex 300Tdi Disco:
    Oct 2007
    Mahn
    Turns out it was a fuse after all...only thing it wasn't as marked on the diagram on fuse cover..bit weird.
