Adjustments are made at master cyl. as far as I know. The actuation rod is threaded and has a specified setting. I suggest you contact stig0000 he knows his stuff. Hope this helps.
Allan
Hello All,
Just a question, is there diffrent length or types of Clutch Slave Cylinders?
The clutch was slipping more often then not (150,000K) so i decided to replace it while i was home this weekend.
Replacement all done, old clutch is a bit so so. Have it all back tpo gether and now i can not disengage the clutch to engage gears.
So i am thinking problems is either Slave is bypasing and in turn U/s
or
I require a diffrent length shaft on the slave cylinder.
Has any one come across this before?
any thoughts appreciated, would like to drive to work on monday, not walk.
Dutchie10
 Wizard
						Wizard
Allan
