1. Barr's Leaks - unlike an expansion type core plug, this is unlikely to suddenly fail.
or
2. If I am correct in recognising where we are, that is a 518272 core plug. It is screwed in.  To remove it you will probably have to drain the coolant, allow to dry, apply heat and penetrating oil repeatedly, and this will eventually enable it to be removed either by drilling two holes to take a pair of pins on a suitable lever, one hole to take a large Ezyout, or weld on a bolt. The thread will probably need some attention - I have an idea this is a funny thread, but Brian Hjelm will sell you a tap to clean it up. A new core plug can then be screwed in with an appropriate sealant (see Loktite Range - one includes teflon).  The thread does not have to be in very good shape if you use a sealant.
Hope this helps,
