Thread: Disabling Td4-EGR-valve
    Somewhat North of Cape York...
    Hi chaps,
    anyone here who can advise me about the easiest way to effectively disable the EGR-valve on a Td4-engine? Don't like all the goo in the IC...
    Thanks and cheers
    Last edited by Jojo; 4th September 2010 at 11:41 PM. Reason: Spelling errors courtesy of a knackered keyboard
    Johannes
    There are people who spend all weekend cleaning the car.
    And there are people who drive Discovery.
    Hunter Valley
    The easiest way it to disconnect the solinoid that operates it. it sit under the intake manifold, just follow the vacuum hoses from throttle body. It will bring up a fault but wont bring on engine check light.
    the best way is to make a plate up and block EGR pipe work. best spot for that is the pipe from EGR cooler to throttle body, You will have to put it on the cooler side as throttle body side had a tapered seal.
    Does the same apply to the L series diesel?
    Hunter Valley
    Its been a while since Ive seen a L series, But from memory the EGR plums into the alloy pipe that runs over the rocker cover. It connects the intake manifold to the intercooler hose. Unbolt off there and make a blanking plate to go inline.
    Thanks for that.
