Hi Nero,
You have found one of the best. It actually has a 120" wheelbase, and was an Australia-only model, modified by Jaguar-Rover Australia.
The engine is the strongest, most reliable and longest lasting that has been put in a Landy from factory. If its a 4 speed, the gearbox is strong, but costly to rebuild. I've had quotes of $2500 to rebuild mine, whilst a second hand one might go for $400 max. If its the 5 speed, it is a little weaker but can be swapped with a later gearbox (R380) using the same bellhousing.
These vehicles tend to get rust around the rear of the chassis and in the firewall. The firewall being the hardest to contend with i'd say, and a lot of it is hard to access/see.
All in all, it is a horrible vehicle and you should give it to me.
					 we used to nail a couple a year at work across 8 vehicles.
