                                                7th September 2010, 09:18 AM
			ARB Bullbar - TD5
					Has anyone successfully adapted the newish Puma ARB bullbar to a TD5?
 Will it even fit?
                                                7th September 2010, 11:30 AM
			TD5 Bar
					I tried to swap mine over and no it doesn't fit, the problem is that it doesn't go back far enough, it would be possible to make up extension brackets to adapt it with a little welding here and there, but I ran out of  time and lashed out for a new ARB one.
                                                7th September 2010, 09:08 PM
					Hi Carlos,
 So did have a TD5 Bar, and then try and fit that to a Puma? I am after anyone who has tried to retro fit a New (Puma) bar to the older TD5.
                                                7th September 2010, 10:45 PM
                                                #4
			Oops
					Sorry Lightweight, I didn't read it properly, it never occurred to me that anyone might want to go that way, having said that I reckon it would fit and you would simply have a little more clearance behind the bar.
