Results 1 to 10 of 25
Thread: Puma fridge mounting in passenger seat position
    Jun 2008
    Darwin
    Just back from the cape and thought Id post a shot of the fridge in our Puma.
    Daniel at Mulgo helped out with the design and construction.
    It was a great help leaving the rear area free for storage.
    With a small bracket on the passenger door hinge it opens to 90 degrees helping the access to the fridge.
    It just bolts into the seat bolts and took me 10 minutes today to take out and replace with the seat.
    See my previous post for photos from the cape.
    Cape York at last. Thanks to Daniel @ Mulgo
    VladTepes's Avatar
    Bracken Ridge, Qld
    Hmm got any bigger pics ? Pics of the frame itself ? Pics of it in the swung out position ?
    I was thinking of doing exactly the same thing, myself.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    May 2003
    On The Road
    What?
    taking it to Mulgo for a fitting??
    miky Guest
    I think it is the door that opens to 90 degrees.
    The door system is really poor on my 2010 110 wagon.
    Does not stay open. Needs a much better method.
    Either way, if the door now opens all the way, that would be a worthwhile idea.
    Normanhurst, NSW
    Quote Originally Posted by miky View Post
    To get your rear passenger doors to open further, remove the door stay bracket from the bulkhead behind the front seats and elongate the mounting holes in the bracket so that it can be refitted closer to the outside of the vehicle. Be careful not to allow doors to open too far otherwise they'll put a crease in the 'B' pillar.
    It's a while since I did it but IIRC I elongated by fileing to about half a hole extra - knowing Landys though, this could vary from vehicle to vehicle.
    I can't help you with the 'locking' of the door stay but I know Mulgo do a very nice gas strut for the Defender rear door and Daniel may be able to do something similar for the side doors.
    Roger
    Mildura,NW VIC
    It's really quite simple.
    When I wanted to fit a slide to accomodate the generator I simply undid the bolt on the door retainer, measured the distance between bolt holes with door at 90" ,cut a small bracket drilled 2 holes to suit.Then bolted said little extension bracket to the 2 holes .Easy
    Have had both rear pass doors at 90 ' for 4rs or so.
    Also great makes it much easier for passengers to get in but excellent for access to child harness etc
    Mary
    will post a photo if anyone wishes.
    "Some people walk in the rain,others just get wet!" -Roger Miller
    hahahahahah I did this to my car months ago..I thought everyone put their fridge there
    Jun 2008
    Darwin
    as malleefowl said
    "undid the bolt on the door retainer, measured the distance between bolt holes with door at 90" ,cut a small bracket drilled 2 holes to suit.Then bolted said little extension bracket to the 2 holes"
    The door opens 90 degrees, just stops shot of the B pillar. Make access great for the fridge and now without the fridge for putting junior in the baby seat. The fridge just opens where it is. The top of the fridge just clears the roof when open by a few inches so the positioning and hight is important. I think Daniel at mulgo has all the measurements. Will try to post some shots of the frame.
    miky Guest
    Oh you guys have just made my day (or should I say evening?).
    What a great idea. Photo would be nice.
    Must contact Daniel about a gas strut for rear door, and will ask about one for side doors.
    Jannali - NSW
    Here are a few more photos. In one of them on the bottom left hand corner you see the door opening extension (red circle).
    Daniel
    Mulgo Pty Ltd
    Expedition vehicles & equipment
    69 Anderson Road, Mortdale NSW 2223
    p 0438 183 507 / www.mulgo.com.au
    Purchase your 4wd gear online:
    www.expeditioncentre.com.au
    follow us on facebook:
    facebook.com/expeditioncentre
