Results 1 to 10 of 26
Thread: TIG Anguish :( Can't Fillet or Lap weld Aluminium
    Adelaide Hills - SA
    Anyone here a TIG welder, and does aluminium?
    See attached photos for the mess I am making! Photos are basically the same, just one with a flash and one without.
    I can run a reasonable bead with a filler rod on flat sheet, and can join with a butt weld 2 pieces, but as soon as I try and do a Lap Weld or a Fillet Joint it all falls apart.
    My basic setup is an AC/DC Kemppi 230A unit, no foot control, air-cooled torch, running pure Argon, and "White tipped" 1% Zr tungstens (sharpened slightly to a blunt cone, not a fine sharp tip).
    I am experimenting on Aluminium checker plate, just under 3mm thick. Am brushing it with a stainless steel wire brush - which is not used for anything else except aluminium brushing.
    I seem to be "eating" the top sheet. I have tried numerous combinations of:
    - Amps - around 80 but as low as 40 and up to 140
    - Stickout distance of the tungsten
    - a new tungsten
    - putting the gas flow from 6LPM up to 8LPM
    - going from a #6 shroud to a #8 shroud (made it worse)
    - Fiddling with the AC mix, and injecting a bit of DC time
    - Pulsing the AC
    - Adjusting the AC frequency (between 60 to 120, even a bit at 200Hz, but mainly around 100Hz)
    I seem to have contamination, often when I try introducing the filler rod. It starts spitting at me and gets the nasty blueish flame edges.
    Anything anyone can suggest most welcome, as I am ready to go back to MIG welding steel and forgetting aluminium (well, that's how I feel tonight.....)
    David
    Apr 2007
    NW Tassie
    All the tigging Ive done has been stainless so no clue really. Could it be creating an air gap between the overlap so your top plate is getting to temp but the lower plate is way to cold. Why do you need to overlap, can you engineer to do fillets as like you say your flat plate welds look ok
    blaze
    Adelaide Hills - SA
    Well - my test welds are with the two flat sides of the chequer plate together, so not much of an air gap (at least not as much as there would be if the plates were around the other way....). However, they are just sitting on top of each other with gravity - do you think clamping them tightly together might help?
    The torch is 80% focused on the base sheet so that's where most of the heat'd be going I reckon. Torch angle would be 10 degrees off verticle (looking from the front - pointing in the direction of the weld) and 20 degrees angled back "into" the join.
    Jun 2008
    Alstonville NSW
    It has been 25 yrs since my tig time but the edge of the overlap top plate does not have the heat dissipation that the base plate will have and as it is relatively thin at 3mm and presumably with air gap checker plate minimal contact with the base plate, so I would have started with a bead on the base plate and then run the bead up to the top plate edge with the arc flame largely on the bead.
    Adelaide Hills - SA
    That is basically how I am doing it. I can get a nice shiny puddle on the base sheet, but I can't get the top sheet to "wick" together into the bottom sheet puddle.
    It's like dealing with "reverse mercury". The two pools of molten ali do not want to join up and become one
    Jun 2008
    Alstonville NSW
    As said it has been a long time but we did have a white paste that was a flux for aluminium. Only remember using it for a couple of small jobs I did with an acetylene torch but cant think why it would not work with TIG. You are trying to do a challenging weld. The difference in heat sink with the 2 plate and a low tolerance between just right and a puddle not easy.
    99.87 MB
    I've got no idea with the Kemppi as ours is an ESAB, also I'm not much into TIG work.
    We turn the AC balance of the phases right down to the lowest base level and don't play with it - this stuffs the welds and burns the tungsten if you run too much heat into the tip.
    We don't run DC at all with Aluminium - it doesn't allow the TIG to penetrate the Al oxide layer. Run DC when you are TIGing steel.
    The high frequency is to start the arc without striking the tip and contaminating it, and so with AC current used for Al it needs to stay on all of the time as the current cycles.
    You also need to sharpen to a tip with the grind pattern running down to the tip (ie not around) to prevent the gas from swirling on the tip.
    Without being there, I would have also thought that you'd be running somewhere around 40amp to start at least - it just sounds hot, and you may also try to get more filler into it.
    As I said, I'm not into TIG so others may have better info.
    Slunnie
    Adelaide Hills - SA
    Thanks Slunnie - The DC thing when welding Al is called "Mix" mode. It mostly runs AC, but for a short period (maybe 20%) it goes to DC to get more penetration, then flicks straight back to AC mode. It happens so fast you can't see it, you just hear a slightly difference tone when welding.
    99.87 MB
    Quote Originally Posted by spudboy View Post
    Ah thanks for this. Our machine doesn't have that. This is more than just altering the time balance between the AC phases by the sounds of it.
    Slunnie
    Sep 2010
    east gippsland
    Ho Spudboy, i too have taken on tig welding in my garage and had similar problem, all solved with the following
    - clean ally with white sprit and wire brush as per uour doing
    - use the correcdt type of filler rod 5356 is great for structural ally ie:6xxx or 7xxx series or for 5xxxx series 4043 or 5356 will do fine but 4043 has better weld properties.
    - gas flow should be 10-12 ltrs/min, no higher
    -frequency at 100-120 is good
    Do youy have AC balance? It controls the percentage of time that the electrode is postive and negative. more time positive = more heat input more time negative = more cleaning effect on the material. Start at about 50% then as you get better go with more pos.
    Now all that said and just guessing really i'd say that you need to start with attaining your molten pool on the main piece of material then wash across to the edge of the other piece, but once you have your molten pool on the main piece add some filler wire then wash to other piece of material edge.
    Mate i have no idea if this will help but it's what i do and i've been getting some really good welds. That said for the first few days i was where you are.
    Keep at it it's worth the effort!!!!!
