Results 1 to 2 of 2
Thread: Poly Air bag install question on a 130
    Hi all
    I installed new suspension on my 130 today. 2" lift Dobinson springs, matching Bilstein shocks, coil retaining plates all round and Terrafirma front shock towers.
    I had a set of poly air bags to install into the back coils, but included in the kit is a large steel plate which is bolted to the coil top hat by drilling 4 holes and attaching it with bolts. Not sure how this is done without the bolt head touching the top of the coil spring or the top rubber mount inclued in the poly air kit.
    I was thinking of welding the plate to the top of the coil mount. Anybody done this?
    Andrew
    Andrew
    1998 Landrover Defender 300Tdi 130 HCPU Expedition
    1972 Peugeot 504 Sedan - Daily Driver
    Oct 2007
    Yes I welded mine on some time ago, and no problems with the set up at all.
    Brid
