The diff sounds a lot more like the Detroit Locker rather than the TruTrac
Hello Can someone tell me if a true trac diff in the rear of a disco 1 deisel makes noises as it goes around corners or if you are reversing and turning at the same time? Noises as in clunck clunck clunck.
I have been told this is normal as its always locked while in the straight ahead position and disconnects when turning which is the clunking I hear as it is disconnecting.
I have jacked up vehicle and if i turn one wheel in the forward direction the the wheel on the other side turns in the same direction, not opposite directions like a normal open diff. The noise is louder sometimes than others moreso if its cold.
Reason I asked is I sold a disco and the person who bought it has been told the diff is stuffed, but i had no problem with it apart from the noise when i drove it albeit not for very long. I dont know if the mechanic who is diagnosing knows that this is a locking diff.
Advice please
ta
Brad![]()
Range Rovers Have Charactors inside them
LROCWA Ex member 23 years
1971 Series 2A
2004 Discovery2a V8 Auto
2003 Discovery2a TD5 Manual
1982 4door man (sadly now gone)
1989 Vogue auto
2011 TDV8 Vogue
What would life be without a Rangie?
Slunnie
Thankyou this is what I needed to know as I got the disco not knowing what was in it and have been told it was a truetrac, but you may be right
1971 Series 2A
1989 Vogue auto
2011 TDV8 Vogue
I had a true track in my Disco 1.
If you fitted the full locker to the back which is most likely then yes you get the ratchting. I found the slower I went around round about’s in particular the louder" it seemed to sounded.
I also fitted their soft locker to the front. I did find at slow roundabouts that the vehicle tended to shudder as the lockers ratchted. Just engaged the clutch
Great bit of gear. Perhaps, wish I had fitted to the rear of my 2001 TD5 Def in stead of ARB.
