 Originally Posted by
korg20000bc
				During its rebuild my 2a seems to have dropped one of its plates that the top hinge bolts fix to.
Can anyone suggest what to do about it?
Could a long bolt be put through to the next layer of bulkhead with a plate stopping the sheet metal being crushed?
 The top hinge plate is in a square tube about six inches long and open at the bottom. It should be possible to feed a bit of flexible wire down it and pull up a replacement plate - I was able to get my fingers into the bottom of the tube from the engine side. Once you have it up into place, you have to hold it there, which may present more problems if you want to retain the ability to adjust the hinge, but this would also be a problem with your idea. If you can manage without this ability, a suitable adhesive would work. An alternative would be to make the replacement long enough to reach the bottom of the tube, where it could be temporarily held, for example with a bulldog clip, or even a large dollop of blutack, until the hinge bolts are started.
Hope this helps,
