Hopefully picking up the P38 this week, and so have been spending some time looking up various options for Sat Nav. I was quite keen on a factory jobbie, just to keep things looking stock, and even found a complete 2002 kit from a vogue, but at $1k, I just couldn't justify the 10 year old technology, especially when there are more modern versions available for a fraction of the cost. The OEM also has no provision for a reversing camera, which is the main reason for looking at SatNav options, and a bit of a must for the W.A.F.
I also took a look at the various home made 'carputer' type setups, and was impressed - some look almost factory installed. Only issue here, for me, is that it's simply too much work. I did consider integrating an all in one SatNav unit, but I have too many other projects on the go, to be able to justify starting another one.
With the goal being not having something stuck to the middle of the windscreen, I have stumbled across one of these...
It replaces the stock mirror (they have clip on ones too), and does everything I need - bluetooth hands free with FM transmitter, SatNav and Reverse camera. It also does some things that I don't need - movies, music, photos, etc.
I've even managed to find somewhere that sells them dirt cheap
3.5 Inch GPS Rear View Mirror with Navigation Bluetooth FM 2GB NAND Flash AV-IN GPS-935 [GPS-935] - US$169.90 : Cars-electronics.com
Has anyone had any experience with these? or seen one up close? What did you think?
The other question I have relates to the auto dimming mirror. How easy are they to remove, and are there any issues with having it disconnected?
All comments greatly appreciated.
Mick.
