Thread: Landcruiser 80 Shocks for Defender
    JC Rover Guest
    Hi everyone. This is my first time, so be gentle. I'm upgrading the suspension in my 01 Defender. I have ordered custom 3 inch springs from Dobinsons. Unfortunatley there is not much available in long travel shocks for the Defender. It bugs me that all the good stuff is made for Landcrusiers and Patrols . My question is this. I know Landcruiser 80 series front shocks fit the defender. But does anyone know if the Landcruiser 80 series rear shocks fit? I'm after a bigger bore shock.
    Qualified yes.
    They bolt in upside down.
    Doesn't worry a Bilstein, but conventional shocks won't work properly.
    Max P
    Sandstone Point Qld
    I know sum defender owners use GQ patrol shocks with a pin to eye adaptor
    Aaron & Jacinta
    1994 300Tdi Defender
    NE Victoria
    32.83 MB
    You are aware that if you fit longer shocks you will need to move the mounts.
    Tony
    May 2006
    Woolgoolga
    i run 80 series fronts, GQ patrol rears with pin eye apapters, works well.
    I run extra long OME comp spec shocks,meant to fit the front of a raised 80 series.I run them front and rear,with modified mounts and Dobinson Flexicoils.
    Wayne
    NSW far north coast
    GQ/GU Nissan leaf rear dampers are eye top/pin bottom and have 10"+ stroke but the valving is all wrong.
    JC Rover Guest
    Thanks people for the assitance. Terrafirma do a long travel shock, 5 inch travel I think. I would prefer something Australian, tried and tested in the outback. Planning on doing the Simpson etc next year, if I can con the better half into sitting in a defender for two weeks . I'm thinking the Landcruiser Old Man Emu shocks should be long enough.
    Aug 2009
    Leicester UK
    Quote Originally Posted by JC Rover View Post
    OME make a plus 5in shock too, to fit the Defender, the same size as the Terrafirma unit, its a pin to pin unit so you will need new upper mounts, an off the shelf item.
    Quote Originally Posted by Crackerjack View Post
    That is what I run
