You have a rear Maxi drive locker. Are you contemplating replacing it and if so, I'm curious to know why ?
Does anybody know if a County bonnet will straight swap with a 98 300tdi bonnet ??? Or if not, what other type bonnet might fit as a straight swap.
Also what bumper would bolt straight on as a replacement for the winch bar ?? Are Series, County, defender bumpers all the same ???
And finally, to remove an arb air locker from rear axle it needs a hemisphere ?? to replace.
The reason for asking is that "Walter + Sues" 130 Dual Cab has now been declared a write off, but they can remove accessories from vehicle as long as they replace removed items. Obviously they don't have much time so if anybody can help with any of the above items they'd be most grateful.
'95 110 300TDI, F&R ARB Lockers, Twine Shower, Aux Sill Tank, Snorkel, Cargo barrier, 9 seats, swingaway wheel carrier, MadMan EMS2
'85 110 Isuzu NA 4BE1 3.6l Diesel, 0.996 LT-95, Rear Maxi (SOLD)
'76 SIII 109" Nissan ED33 5-SP Nissan GBox (SOLD)
Hi Rod, I'm not replacing mine, but need to get the air locker removed from the dual cab as it's only been fitted a couple of months. Unfortunately Arb don't have the bits they removed when they fitted it.
Yeah all the land rover bonnets pre the puma are the same
The front bumper of a series will fit a 110. The only difference between the series and defender front bumper is the series one is stronger and thicker
Sent from my iPhone using Tapatalk
95 300 Tdi Defender 90
99 300 Tdi Defender 110
92 Discovery 200tdi
50 Series 1 80
50 Series 1 80
www.reads4x4.com
Bonnets interchange
Just pop the locker out, put the cover plate on and lock the centre diff
