Thread: oil in timing belt cover
    Jul 2009
    Forest Hill / Kyneton
    I got myself a wading plug the other day, screwed it in and went down to the car wash and gave her a good blast underneath. I've got an oil leak and I wanted to find it. I thought it may have been the sump gasket since that is oily and there is always a drop ready to come off the low point of the sump.
    Anyway, thismorning I thought I'd better take out the plug. Things looked better under the car and no obvious oil leaks. Took out the plug and out flowed the oil, probably about an egg cup full.
    Where does it come from and is it important? I'd like to fix it for the sake of the driveway but if its not a big deal but is a big job to fix I'll have to live with it.
    Its a 200tdi manual disco.
    Last edited by Disco Brian; 26th September 2010 at 12:11 PM. Reason: additional info
    On a 300tdi, if its the wading plug at the front of the engine (there are two), then its the front seal which requires the timing cover case to be removed. It's not a hard job, and on a 300tdi I'd put up with it until the timing belt was due to be replaced and do the lot at the same time.
    Hunter Valley
    Quote Originally Posted by Taz View Post
    I disagree, the oil gets on the belt and the belt will fail early.
    Replace the cam and crank seals and crank O-ring. You will probably need a belt as the oil will of damaged it, also check the tensioner and idler bearing while its apart.
    Jul 2007
    Melbourne, VIC
    Quote Originally Posted by woko View Post
    x 2
    Also replace the o'ring at the back of the crank seal on the crank shaft.
    Jul 2009
    I had the belt replaced early in the year, about 13,000 kms ago. The mechanic showed me oil on the old belt and told me that it was good that I was having it done. I don't know where that oil came from since the car didn't leak until that service. So now the car leaks and I hadn't planned on replacing the belt for a long time. Will have to weigh it up.
    Adelaide - Torrens Park
    What is more inconvenient?
    Fixing it now with the associated costs or fixing it later when the belt fails due to oil contamination in the middle of the night in the pouring rain when you are running late for something important...?
    Jul 2009
    Quote Originally Posted by BigJon View Post
    I asked the question and I didn't like what I heard. I'd better start studying the manual and work out what needs to be done. I'm not keen on having someone else do it after the lousy job the pros did last time.
    Quote Originally Posted by MinniTheMoocha View Post
    Anything else I should be looking at? I'm hoping I should be able to do a job like this on my own in a weekend with no special tools and only following my workshop manual. Am I on the right track?
    Jul 2009
    New Zealand
    Hi,
    Iv'e got a 300tdi which had a full rebuild 30,000ks ago, which has also developed this problem. After about a month with a front wading plug in, there was a small amount of oil which came out when I withdrew the plug.
    Previously the local landrover experts had quoted about 8 hours labour for changing a cambelt - I presume this will have to be done along with all the seals as has previously been suggested?
    cheers Greg
    Jul 2009
    Quote Originally Posted by Discovering NZ View Post
    cheers Greg
    If experts are quoting 8 hours I think I should allow myself at least twice that.
    And yes, I syill haven't looked at it.
    klappers Guest
    Quote Originally Posted by Disco Brian View Post
    not a massive job and can be comfortably done in a weekend. The only that you you will really need is :
    1. A deflecting beam torque wrench of some sort and
    2. A 9.5mm bolt or similar to hold the pump timing in place.
    Also a crank locking pin as well, but this is not necessary. (when i did mine the person that did the clutch did not put the timing mark back in the correct location so I had to use the woodruf key and the crank pulley as alignment)
