Thread: Oil Switch Location
    Oil Switch Location
    Hi All,
    My 96 300 tdi defender oil light is coming on at idle only, after driving about 20km. I recently replaced the oil filter and oil with what is recommended in the manual and as the oil level is slightly high so I though I might check out the oil pressure switch. Is this the correct course of action and is the pressure switch located just next to where the oil filter screws on , or elswhere ?
    Williams West Aust
    Was reading a similar thread today,400HPongas was the author.I hope you havent got his senario.
    Will look and post the link.
    LOVE THAT OCEAN LINER
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Camp Hill Queensland
    Yes, the switch screws in near the filter. Obviously has a wire coming out of it.
    How many kms has your engine done ? Other TDI300 owners are reporting problems with big end bearings wearing around 250k, manifesting itself by the oil pressure light coming on.
    400HPongas had a 200TDI so not sure how relevant his thread is to your problem
    '95 110 300TDI, F&R ARB Lockers, Twine Shower, Aux Sill Tank, Snorkel, Cargo barrier, 9 seats, swingaway wheel carrier, MadMan EMS2
    '85 110 Isuzu NA 4BE1 3.6l Diesel, 0.996 LT-95, Rear Maxi (SOLD)
    '76 SIII 109" Nissan ED33 5-SP Nissan GBox (SOLD)
    Williams West Aust
    Here you go.
    Oil Thermostat 200/300 TDI
    Andrew
    My 300 tdi has 150 000 km, has been serviced regularily . I did the last oil change because it had only gone 4000 km since last service , but was 18 months ago, so thought I'd put fresh oil in.
    Williams West Aust
    Tis only a baby.
    Hopefully just a faulty sender.
    Andrew
    Jan 2010
    Newman WA
    Sacred blue mon amy , its DEJAY VOO
    Hey rick130 , have we seen this somewheres before ?
    Another glass of Shiraz please !!!
    Yep , I had identical symptoms but it was in a 200TDI and not a 300TDI .
    Now offcourse a 300 TDI has a overhead cam and no cam bearings and a oil pump that is wrapped around the crankshaft , so my problem once found could not apply to a 300TDI ,especially at only 150,000k instead of 400,000K .Cest imposseeble !
    Whaddya reckon Rick130 ?
    However I or should I say we , would be able to trouble shoot the issue , given the right infomation !!!
