Results 1 to 10 of 16
Thread: Reversing a Holden Conversion.
    Perth WA
    How hard is it to reverse a Holden Conversion to a SWB Chassis?
    I am wanting to return a Series 2 back to a 2.25 litre, but I am wondering if I should just be patient and save up for a new chassis.
    Anyone done this before?, I guess the general condition of the rest of the chassis is a deciding factor, but the rear cross member seems very sound.
    J
    d@rk51d3 Guest
    The only chassis change would be to the front crossmember (a section was somtimes cut out to allow a taller radiator to slip in). And you shouldn't need to touch it, unless they buggered it real bad, or moved it.
    You may find the radiator support panel has been narrowed, to allow the radiator to clear the Holden 6. Re-using the panel will leave a few extra inches between the rover 4 and the radiator.
    Narrogin WA
    Well it depends what has been done to your chassis when it was converted.
    A new crossmember (if needed) is easy enough to make, as are the engine mounts, or you might get lucky and be able to cut them off a donor chassis.
    Give your chassis a very thorough poke and prod with a centre punch and hammer so that you can find any thinned, or holed areas first and then you should be able to formulate a plan of attack,
    Cheers Charlie
    Mareeba
    The only thing usually done to the chassis, with a holden conversion, is the very front crossmember is chopped off or trimmed. The radiator support panel is usually chopped up to move the radiator forward but that's just nuts and bolts to replace. Once you remove the motor and the radiator support panel you can replace the front crossmember easy (although the steering box is bolted to it). Should be able to cut one of someones wreck and weld it in.
    Perth WA
    Thanks for the quick and helpful replys,
    I do have a spare radiator support panel to replace the chopped one
    and it looks like the front cross member is about 3/4 gone. there has been a steel rod weleded between the chassis rails just in front of the crossmember.
    Fingers crossed the engine mounts are still in the original positions.
    Have noticed some rust in those square ends above the dumbirons where the bumper bolts onto though.
    I guess a dismantle and inspection is the only logical next step.
    J
    Dec 2009
    Queensland (though occasionally elsewhere)
    Hey it's interesting reading these posts. When I converted mine back to a 2.25 ten years ago, all I had to do was sort out the radiator panel. The crossmember had never been moved and it was all just a nuts-and-bolts job. Mind you, with the Holden engine in it, I had had no room to spare......
    darwin, nt
    Crossmember 3/4 gone? Do you have a grey motor in it? It always struck me as the worst conversion possible for a Land Rover, because of the mounting system. Red motors were a better fit because they were mounted similarly to the standard layout. The front crossmember still needed trimming because the Holden fan sat lower than the Landy unit, and therefore needed the radiator to sit lower (ideally right where the crossmember is).
    Dan.
    69 2A 88" pet4, 68 2B FC pet6, plus other parts cars and pipedream projects.
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by dandlandyman View Post
    <snip>
    <snip>
    I guess that up until 1963 Grey motors were the only Holden option and then at least for a couple or more years the red motors were out of new cars and relatively expensive so the grey motors continued to be fitted.
    By 1970-'72 no one considered fitting a grey motor.
    Mareeba
    The mechanics of the time could really get the greys to honk.
    Apr 2010
    Victoria
    I have a Red 202 in my 2A. The other day i took the radiator out to get it repaired and it is still the original LR radiator. I have had no modifications to my cross member either. And no mods have been made to the radiator support. So obviously while modification may have been common clearly not everyone did this. It doesnt seem to be a very tight fit in the engine bay either. However 'tight' does not compare to a v8 in a vs commodore (Im talking about working on the distributer)
