there are no timing marks on the damper wheel at the front of the motor.
you have to carefully rotate the engine to top dead centre via the hatch on the flywheel casting and when you think that tdc is correct and the timing marks, according to the manual are all right, then use the timing bulb method to set the timing.
land rovers of series one type are very forgiving and an few degrees one way or the other are superfluous , in my opinion.......
as for filters, cannister types were the norm and virtually unobtainable today, I have some but for me, I recommend just to change the oil at least 2 times a year and a pre flush before changaing the oil.
Your treasurer will last for many years to come......
  Reply With Quote timing
 timing
					 timing the engine via this method
