Originally Posted by
stig0000
i have gotten a free ECI rust thingy from work, one prob is that the copper pad is missing, (resion why i have it) other then that it works fine,
just a qwick Q, there is only one wire that gose to the pad thingy and since thats ment to be metle on metel anyway, can i just put a spade conector on and run it on a post on the chassis/body,,
im not asking weather you think they work or no, i personally think they dont
, BUT its FREE and im a freak about no rust, so you not try it out,
The unit I have has multiple anodes. There are about 12 single wires that come out of it and each wire goes to a sacraficial anode which is attached to the body with a thin strip of double sided adhesive. (the anode does not actually touch the body and the instructions said to make a scratch right down to the bare metal immediately under where the anode is to go)
Cheers......Brian
1985 110 V8 County
